Side panel for Fiamma awning (1 Viewer)
Oct 7, 2013
5,894
36,913
South Wales
Swift Escape Compact
Since 1988
Many years ago we had a “windstopper “ end panel for a Fiamma wind out awning.
It was best described as a plastic fine mesh and stopped a lot of the direct sun while allowing us to see through it.
We have been trying to buy one again but all we can find are end panels with pvc sheet and clear plastic windows. These obviously let the sun through.
Does anyone know of a supplier for what I have (tried to) describe?
Zoppydog
Jul 19, 2013
335
237
Suffolk
No longer own one
Do you mean LIlypad Leisure who make wind blocker shades?
maison
Oct 7, 2013
5,894
36,913
South Wales
Since 1988
Frankly, I don’t know, but I will google them to see.
Many thanks for trying to help.(y)
Edit
Yes. Having googled it, although not the same it will certainly do the job.
Thanks again.
maison
Oct 7, 2013
5,894
36,913
South Wales
Since 1988
@Clickem
I may well be interested, but only in the side panel.
I will need to measure our awning, when extended to see if the “standard” fit will be OK. We also need to check if the panel will fit both ends.
As the weather forecast for tomorrow is gales in our area :eek:it may take a couple of days!
I will PM you when we have the details.
Thanks for the reply!(y)
maison
Oct 7, 2013
5,894
36,913
South Wales
Since 1988
Apr 22, 2018
6,823
12,578
Herts.
Adria Coral lowline
I think I have what you are talking about, and it’s made by fammia. Just a mesh end panel, and a pole that can be used on one or the other end of the awning.
maison
Oct 7, 2013
5,894
36,913
South Wales
Since 1988
That sounds like what we had.
Is there any identifying mark on it that I could use to “google”, please?
Apr 22, 2018
6,823
12,578
Herts.
Adria Coral lowline
I will dig it out tomorrow, I also have the instructions so there might be a part number.
Caggsie1
967
4,538
North Wales
Hobby
Since 2008
@maison they come in 4 sizes. It depends on your projection, starts at 2 m. Use the drop down for the choices. Depends on the way it connects to the awning. I understood that they could be interchangeable, but do think going to your local stockist, they’d give you the answer you require.
