Securing Satellite to the roof. (2 Viewers)
lorger
9,666
90,548
Dumfries
Knaus Sun 650MEG
New Snipe Satellite arrived yesterday so hopefully if i have time will start to fit it in the morning, depends how i feel after tonights Night shift.
Question is what adhesive do you recommend for fixing it to roof and would you use only this or screws also.
43,334
49,533
Sikaflex....no screws.
Roof needs to be THOROUGHLY dry and clean.
Before fixing the baseplate put 4 washers just inboard of the corners of the plate, sikaflex needs a small gap between surfaces to cure properly and remain flexible.
Leave 24 hours to cure fully
11,956
16,570
In case you need more weight of opinion ............ exactly as PJ says :).
Could you possibly measure the thickness of your mounting plate? - I need one & I have no intention of buying the correct expensive item - just need to know what thickness to buy.
lorger
lorger
9,666
90,548
Dumfries
Knaus Sun 650MEG
Will do that for you before fitting
wingman
1,217
3,333
Romford, Essex
Coachbuilt Lo-Profile
I didn't fit my Snipe permanently to the roof.
(a) I didn't want any more holes in the roof and
(b) It would mean difficulty if I sold the van. ( I would either have to buy a new Snipe, or clean off the gunge, risking damage to the roof or paint colour differences)
I just pop mine up on the roof via the large Hekki rooflight or (security permitting) put it on a small camping table.
dshague
996
302
VAN CONVERSION
20 years
fitted mine last week .its very easy .lots of cable come with it .before fitting i did a test on drive picked up astra 2 quickly used Broken Link Removed
Steve N Tracy
1,235
3,728
Southampton
4 Years
I used Sikaflex 252 without any screws to secure my Megasat (Snipe Pro Clone) to our van.
Judge Mental
Sep 2, 2009
6,650
5,883
Sarth London
Possl 636 FR panel van
1994 and beyond...
As long as you don't forget when you drive away:(
lorger
lorger
9,666
90,548
Dumfries
Knaus Sun 650MEG
Planning on trying it before we fit it just to make sure alls ok, heading off this weekend so might just pop it out on roof before fixing it.
Did you just use this on its own or with screws
dshague
996
302
VAN CONVERSION
20 years
Followed instructions used the screws supplied.you have to drill a hole for cable whats a few more .screws hold down mounting plate firmer onto roof
lorger
lorger
9,666
90,548
Dumfries
Knaus Sun 650MEG
Cheers, yes I'm ok with drilling hole for cable just wondered if you done them for the plate as per instructions as most folk seem to just use the adhesive
laneside
Aug 14, 2009
2,668
6,276
Oradour sur Vayres
Rapido V66
nowhere near long enough
Just Sikaflex holding our Snipe on Gerry, the roof of a PV is soooo thin the screws would do little.
For the first few trips you will stick your head through the skylight to see if is still there and then you begin to have faith in Sikaflex.
Just as an aside Gerry our Snipe has worked really well
18,035
48,140
When fitting my solar panel I put masking tape around the mounting feet have placed them in the correct position. I then lifted them off and could see by the tape where to roughen the paint. I also used the Sikaflex activator but I think meths would be almost as good to clean both the roof and feet.
I then used 3mm tile spacers to create the gap for the Sikaflex adhesive.
I used small stainless steel self tappers for extra security and they do ensure nothing moves while the adhesive is setting.
lorger
lorger
9,666
90,548
Dumfries
Knaus Sun 650MEG
Thanks Alan, its just doesn't feel right not using screws but that was my worry the thickness of the roof. If I have time tomorrow I will set about it before heading off for the weekend. If not I will just throw it on the roof to try it out.
Glad to hear your happy with yours
lorger
lorger
9,666
90,548
Dumfries
Knaus Sun 650MEG
good idea with the tile spacers, I understand about the screws holding things in place just think the less holes I drill the better.
D
deleted-member02
I've yet to fit a Snipe (on wish list) but did install solar and reversing cam at the same time.
This multiple entry gland was a good buy, room for solar, satellite and camera cables (y)
I also used Sika 252 and tile spacers, it's worked well.
lorger
lorger
9,666
90,548
Dumfries
Knaus Sun 650MEG
I was thinking of 251 as i thought this was the one for caravans and motorhomes so what made you pick the 252
11,956
16,570
That's an excellent box. Some of the ones I've seen have most of the base cut away leaving a fairly narrow strip around the base for adhesive/sealant.
D
deleted-member02
@lorger I bought it in a kit with the 205 activator.
I think they're all suitable tbh, even sika ebt from Screwfix would do the job.
My panel's a quite large 140w and it's certainly stuck down well.
D
deleted-member02
Yes, it makes for a very tidy install.
It fits through the roof perfectly although I did slightly tear the wallboard while fitting :cry:IMG_1505.JPG
Aug 19, 2013
2,961
4,292
Wells, Somerset
Elddis 115
since 2004
I've got one of these:
That should work just as well? Good tip about the washers.
2,346
10,190
Alden supply Sikaflex and Sika Akitvator with the dish fitting kit, complete with disposable gloves ... and even if you felt the need, there is no facility on the base to use screws..
11,956
16,570
It fits through the roof perfectly although I did slightly tear the wallboard while fitting :cry:View attachment 97221
I know it sounds wrong but I always use the holesaw from the inside. The worst that can happen then is that it raises a lip if it's an aluminium outer skin & that's easily trimmed. I like your box even more now - it's like the ones I've done in the past using a plumbing fitting & a waterproof box. The ones I've seen supplied with solar kits are as I described in my last post and simply glue to the roof over a pre-drilled hole.
11,956
16,570
I don't like that type - if any water gets into the box it can enter the roof too easily. The one moho has used has a complete base to the box and is held onto the roof by the plastic nut inside. My van had one like yours & I needed to install extra panel wiring. When I got it off the roof it was wet underneath - which might actually say more about the original installer than the box or sealant used :).
Steve N Tracy
1,235
3,728
Southampton
4 Years
Gland boxes are often fitted over holes larger then really needed for the cable size that is passed through this allows warm air from inside the vehicle to travel up through the hole contact the cold casing of the gland box and condensation forms , to avoid this I ether drill holes just large enough to pass the cable through or if using a larger hole somebody else has drilled pack out the hole with insulation.
Gorse Hill
2,364
1,944
Stretford
Burnster Ixeo IT 734
Agreed about your choice, the one Moho used is much better for sealing and maintaining IP
Did look on the site. However there was no confirmation of the box IP rating, looks IP65 but would be interested to know
