The F65 will not stand up to very much, the joints which connect the legs to the front are plastic, the legs are very thin compared to my last Thule awning. In my opinion they are very poorly made.After some advice / suggestions on the best driveaway awning to get please. We have a globecar pvc with a fiamma f65 awning fitted. Ideally looking for something that can stand up to some wintery weather.
Is the fitting of a draught skirt essential and how is this best achieved?
Thanks.
I've also noticed that the components of my F65 are lighter than previous models I've owned, but this doesn't tend to be an issue with 'drive away' awnings, which are self supporting and therefore transfer very little weight across to the Fiamma.The F65 will not stand up to very much, the joints which connect the legs to the front are plastic, the legs are very thin compared to my last Thule awning. In my opinion they are very poorly made.
Just to clarify the F65 and F65s are 2 different awnings, the F65 is usually put on a coachbuilt motorhome whereas the F65s is specifically made for a van conversion.
Cheers Minxy, mine is the 'S'.Just to clarify the F65 and F65s are 2 different awnings, the F65 is usually put on a coachbuilt motorhome whereas the F65s is specifically made for a van conversion.
Cheers jezport, that will likely explain why this one is lighter than the two previous ones on my coachbuilts.The F65s is lighter weight 8kg lighter than the L model on a 400cm
The F65L is heavier duty with aluminium end caps and thicker case
Both can be fitted on Van conversions or coachbuilts
With panel vans having such a wide sliding door aperture, the advantages of having an awning that goes some way to making the open door more weather tight are obvious.i personally do not like driveaway awnings, we prefer a standalone and use the vango Hex air , for us the beauty is we just drive away leaving the awning standing with no fuss of having to detach the awning from the motorhome, really sturdy in the wind and great in the summer
The Ventura freestander looks very sturdy, would it connect into the existing fiamma frame somehow?
Regarding the air type awnings which also look a good option, I read they constantly require a connected pump to maintain the correct pressure. Is this correct?
The F65s also has aluminium end caps according to Fiammastore, so it seems its just the case that's different, hence the price and weight difference, the rest of the components appear to be the same (I haven't studied them in detail, just had a quick shuftie at the info on the website):The F65s is lighter weight 8kg lighter than the L model on a 400cm
I don't think that's quite the case, the F65L is only available in longer sizes starting at 4.0m so no option but to use the F65s (or F65) for shorter ones. However if you need an awning of 4m or more then IMV you really do need the stronger case but there is QUITE a cost difference for the same size of awning, around £190!The S is used mostly because its cheaper to buy
I can't, or won't suggest a model, as it would be down to individual choice and requirements.Overwhelmed by the responses here, much appreciated.
@Kingham can you suggest a specific model please? Seems a whole host available on the second hand market. One that would allow us to open the side door within the confines of the awning would be perfect. The kampas seem to seal well along the sides of the van, how is this managed along the underside of the van? Or would it be necessary to construct some type of skirt as per minxy girls suggestions?
The rear of drive-away awnings differ quite a lot, some have quite high sills where the rear panel zips in but some are quite low and therefore let the wind blow through into the awning itself, plus if you want to use the tunnel part as well as the main part of the awning it will obviously stop the wind coming into that anyway.... I don't get where skirts are required with freestanding awnings ?
