Problem loading photos (1 Viewer)
Feb 24, 2013
13,083
101,448
Bolsover, Derbyshire
Hymer S800
not long enough
I have loaded hundreds of photos to the forum but just lately get loads of error messages, usually they go on after multiple attempts but today is worse than normal tried 10 times and error each time although oddly first one went straight on
We have particularly good broadband speed today and I am getting same problem on laptop with camera photos and iPhone
Is it just me?
Geo
Trader - Funster
Jul 29, 2007
11,757
14,565
Mansfield,Notts
Autotrail Tracker FB
45 +years with breaks
When it happens to me I reduce file size and it pops straight on
DavidG58
Feb 24, 2013
13,083
101,448
Hymer S800
not long enough
funnily enough I have just done the same and it worked for me too, but I never had to before and wouldn't have thought the iPhone photos would be that big?
Jan 19, 2014
9,395
24,781
Derbyshire
Elddis Accordo 105
since 2014
It happens sometimes with old photos, I take a screenshot of it and upload that, always works then.
Geo
Trader - Funster
Jul 29, 2007
11,757
14,565
Mansfield,Notts
It a fenommo Fernimin femo Odd David
all my pics are usually uploaded from my Galaxy and file sizes sometimes go wild I dont know why eithr
7 out of 10 pics ok then two or three need treating???
DavidG58
Feb 24, 2013
13,083
101,448
Hymer S800
not long enough
not sure if the above link will work, but if someone technical can see the images, the first photo loaded fine at whatever size I took it at, the following 2 had to be reduced then uploaded very easily (y)
Oct 14, 2013
811
7,757
Bedfordshire
rollerteam zefiro
10 + years
hmmm mine seem to be ok
Apr 9, 2014
1,307
6,596
Lincs
If I get an error it occurs after the file appears to upload. I find retrying the same file does not work, change the format or the size and usually goes through ok.
Presumably after the upload it's moving the file to a server location and/or converting format and that is when the error occurs :unsure:
Gellyneck
9,235
18,210
More than toes wet now!
Can view them.
When copying and pasting into Irfanview they're all around the same size (1333x1000Mpx - 400 to 500Kb).
Oct 20, 2010
2,248
37,617
Burry Port South Wales
Since 2003
I have been doing the same for a while, completely random which work and which don't. (n)
Cheers
Ed
DavidG58
Feb 24, 2013
13,083
101,448
Hymer S800
not long enough
In case it helps those that know what they are looking for, this is the message I get (y)
sure it must just be a sizing issue, but odd that it is only recently a much bigger problem
Mar 9, 2015
4,544
15,224
Heywood, Gtr. Manchester.
AS Broadway FB
Since 2008
It's been driving me potty. Same message. Only been happening in the last few weeks. Sometimes I've tried the same pic half a dozen times and then it'll suddenly work! Usually I've just given up.
Feb 27, 2011
14,741
76,015
I can see that there are some timeout issues with imagemagik I will investigate.
Feb 27, 2011
14,741
76,015
ok. I have adjusted the php execution timeout. Let me know if this has improved things please.
Jan 2, 2017
175
479
New Forest
Elddis Autostratus
full timing since beginning 2017
15326169091851137194585.jpg yay!! It's the first time in ages I've been able to upload a photo, great(y)
DavidG58
Feb 24, 2013
13,083
101,448
Hymer S800
not long enough
I was full of hope based on above post, but no difference for me o_O
although by resizing I can if that helps (y) just don't know how to resize on iPhone :(
DavidG58
Feb 24, 2013
13,083
101,448
Hymer S800
not long enough
above is the actual image as on my laptop, with size details
by using above resize option and picking L it becomes this below, which I can then upload very easily
If I can find an easy way to resize on phone it will be OKish, although a PITA and only something that has recently happened
Hope there is a fix your end :)(y)
R
Robert Clark
It would be a bit of a faff having to re size images, never had to do that before
The problem only started recently, so I’m guessing that something changed in the back end of the site
Feb 27, 2011
14,741
76,015
Testing testing....
No luck here either .:(
ok. I have just cleared the server log.
If you guys/gals can try again until you get an error then let me know. I can see what the server logs say about it.
Langtoftlad
8,861
150,862
Langtoft, South Lincs
WildAx Aurora FB [PVC]
I always use 'photo & picture resizer' app as a matter of course... probably due to personal parsimony being on a payg SIM... 1p/mb :eek:, so just in the habit of shrinking those 4mb photos to just a few kb :D.
Needless to say I can't recall having an issue with posting a photo.
18,025
48,095
I think the image size limit is 10Mb. I've just tried uploading a 13Mb image and it gave me the error message in post #12. If you are using a mobile phone it is sensible to reduce the file size first. On Android I use Photo & Picture Resizer and reduce the images to around 1600 pixels wide. This app has a logo of a blue square and two arrows. There are other apps with very similar names. I've tried many of them but found Photo & Picture Resizer the best. I don't think there is an iOS version though.
43,330
49,446
If you use Android I use this very simple two click resize app....
https://play.google.com/store/apps/details?id=com.xllusion.app.photoresizer
DavidG58
Feb 24, 2013
13,083
101,448
Hymer S800
not long enough
just tried 5 different photos at full size, all got the same error
edit - but very grateful for you trying to sort it (y)(y)
Apr 9, 2014
1,307
6,596
Lincs
Not sure this is to do with file size as such, the photo @DavidG58 put up was only 3.6MB, most of the images I put up are just under 4MB. I did find one time it errored that I resized the image to about 300Kb and it still errored, changed format and ok.
Reactions: DBK
Feb 27, 2011
14,741
76,015
ok. It should be sorted now.
Please try again and report back :)
