Problem loading photos
Feb 24, 2013
11,909
90,436
Bolsover, Derbyshire
Hymer S800
not long enough
I have loaded hundreds of photos to the forum but just lately get loads of error messages, usually they go on after multiple attempts but today is worse than normal tried 10 times and error each time although oddly first one went straight on
We have particularly good broadband speed today and I am getting same problem on laptop with camera photos and iPhone
Is it just me?
Geo
Trader - Funster
Jul 29, 2007
11,638
13,659
Mansfield,Notts
Autotrail Tracker FB
45 +years with breaks
When it happens to me I reduce file size and it pops straight on
DavidG58
Feb 24, 2013
11,909
90,436
Hymer S800
not long enough
funnily enough I have just done the same and it worked for me too, but I never had to before and wouldn't have thought the iPhone photos would be that big?
Geo
Trader - Funster
Jul 29, 2007
11,638
13,659
Mansfield,Notts
It a fenommo Fernimin femo Odd David
all my pics are usually uploaded from my Galaxy and file sizes sometimes go wild I dont know why eithr
7 out of 10 pics ok then two or three need treating???
DavidG58
Feb 24, 2013
11,909
90,436
Hymer S800
not long enough
Morning Funsters
not sure if the above link will work, but if someone technical can see the images, the first photo loaded fine at whatever size I took it at, the following 2 had to be reduced then uploaded very easily (y)
Apr 9, 2014
1,152
5,530
Lincs
If I get an error it occurs after the file appears to upload. I find retrying the same file does not work, change the format or the size and usually goes through ok.
Presumably after the upload it's moving the file to a server location and/or converting format and that is when the error occurs :unsure:
Gellyneck
6,904
12,195
Scotland
More than toes wet now!
Morning Funsters
Can view them.
When copying and pasting into Irfanview they're all around the same size (1333x1000Mpx - 400 to 500Kb).
Oct 20, 2010
1,883
24,683
Burry Port South Wales / Benidorm
15 Years
I have been doing the same for a while, completely random which work and which don't. (n)
Ed
DavidG58
Feb 24, 2013
11,909
90,436
Hymer S800
not long enough
In case it helps those that know what they are looking for, this is the message I get (y)
sure it must just be a sizing issue, but odd that it is only recently a much bigger problem
Mar 9, 2015
3,621
10,197
Heywood, Gtr. Manchester.
Autosleeper Winchcom
Since 2008
It's been driving me potty. Same message. Only been happening in the last few weeks. Sometimes I've tried the same pic half a dozen times and then it'll suddenly work! Usually I've just given up.
Gromett
Feb 27, 2011
11,441
32,295
UK
Self Build
I can see that there are some timeout issues with imagemagik I will investigate.
Gromett
Feb 27, 2011
11,441
32,295
UK
Self Build
ok. I have adjusted the php execution timeout. Let me know if this has improved things please.
DavidG58
Feb 24, 2013
11,909
90,436
Hymer S800
not long enough
I was full of hope based on above post, but no difference for me o_O
although by resizing I can if that helps (y) just don't know how to resize on iPhone :(
DavidG58
Feb 24, 2013
11,909
90,436
Hymer S800
not long enough
above is the actual image as on my laptop, with size details
by using above resize option and picking L it becomes this below, which I can then upload very easily
If I can find an easy way to resize on phone it will be OKish, although a PITA and only something that has recently happened
Hope there is a fix your end :)(y)
Robert Clark
10,849
116,049
East Sussex
Morelo Palace 85L
Since June 2014 - learning something new all the time
It would be a bit of a faff having to re size images, never had to do that before
The problem only started recently, so I’m guessing that something changed in the back end of the site
Gromett
Feb 27, 2011
11,441
32,295
UK
Self Build
Testing testing....
No luck here either .:(
ok. I have just cleared the server log.
If you guys/gals can try again until you get an error then let me know. I can see what the server logs say about it.
Langtoftlad
6,481
78,173
Langtoft, South Lincs
WildAx Aurora FB [PVC]
Since 2015
I always use 'photo & picture resizer' app as a matter of course... probably due to personal parsimony being on a payg SIM... 1p/mb :eek:, so just in the habit of shrinking those 4mb photos to just a few kb :D.
Needless to say I can't recall having an issue with posting a photo.
DBK
16,154
37,087
Plympton, Devon
PVC, Murvi Morocco
I think the image size limit is 10Mb. I've just tried uploading a 13Mb image and it gave me the error message in post #12. If you are using a mobile phone it is sensible to reduce the file size first. On Android I use Photo & Picture Resizer and reduce the images to around 1600 pixels wide. This app has a logo of a blue square and two arrows. There are other apps with very similar names. I've tried many of them but found Photo & Picture Resizer the best. I don't think there is an iOS version though.
40,091
37,487
If you use Android I use this very simple two click resize app....
https://play.google.com/store/apps/details?id=com.xllusion.app.photoresizer
DavidG58
Feb 24, 2013
11,909
90,436
Hymer S800
not long enough
just tried 5 different photos at full size, all got the same error
edit - but very grateful for you trying to sort it (y)(y)
Apr 9, 2014
1,152
5,530
Lincs
Not sure this is to do with file size as such, the photo @DavidG58 put up was only 3.6MB, most of the images I put up are just under 4MB. I did find one time it errored that I resized the image to about 300Kb and it still errored, changed format and ok.
Gromett
Feb 27, 2011
11,441
32,295
UK
Self Build
ok. It should be sorted now.
Please try again and report back :)
