prize for the most obvious question? (2 Viewers)
dreckly
102
57
cornwall
Back on the road after a 4 yr break
Can I use a domestic combination microwave oven in my motorhome on electric hook up? Or is there some electric magic that I am not aware of and in danger of blowing up my van and/or the microwave? Whilst on the subject I may as well ask if it is possible to use any domestic electrical item in the van without the blowing up thing occuring?
Thank you to all the funsters in anticipation, (inc Bob and Jane the source of all knowledge):Smile:
Just depends on the hook up. If it's a low 6A one you can't, otherwise cook away.
zaskar
1,159
371
5th Wheel
In a word, yes....................BUT
check the power rating of the appliance you would like to use.
Remember that start up current is considerably greater than running current for a microwave.
In general, on large sites, you've a good chance of getting a 16 amp hook up which will happily run any domestic appliance you're likely to take in your 'van, providing you dont run too many appliances at once.
On farms /CL's/ CS's, its likely that you'll get a 10 amp hook up so you have to do a bit more juggling.
837
289
Shropshire based
Globecar
started in 2001
A microwave draws 2.5 times its rated wattage on start up, so a 1Kw will draw 2.5 Kw at start up.
If you are on a 10 amp EHU you may, and should trip out, ::cry: on 16 amps, OK :Smile: but balance your demand.
Same applies to any domestic electrical items.:Cool:
10 amps provides 2300 watts
16 amps provides 3680 watts
Hope this helps
Nomadic
43,339
49,542
you can run anything you want on hookup...microwave, sunbed, jacuzi, cement mixer, washing machine....anything...... providing you dont overload either your own fuse breakers or those in the hookup post.
i use the microwave on hookup or genny if no hookup available.
look on the data plate on appliances to find the watts.....divide by 230 and the result is the amps.....ie: 1000watts = 4.34 amps
on a 10 amp hookup you SHOULD be ok to run upto 2300watts of appiances together.
5amp hookup= 1150watts
16amp hookup = 3680watts.
dont forget to add in your charger etc.
id run slightly less though so as not to trip the hookup post.
The Wallace
367
5
Link Removed, just remember that your are camping! albeit in a tin tent with wheels!
All the power you use has to come in via that one small cable on the side of the van.
By all means do the calculations if you like that sort of thing otherwise just don't behave as if you are in a house with an 100 amp supply - you have a max of 16 amps and sometimes only 6.
geoff1947
988
98
Plymouth
low profile
10 yrs
Sat on site in Spain on 10 amps and use the microwave on medium power. No problem as long as I remember to switch off the kettle, hot air fire if in use ( gets a bit chilly by tea time) but can leave TV ON. just be sensible as someone stated you are camping!!!:thumb:
Hopesy
76
South Gloucestershire
Coach built
With Microwaves don't go by the rating written on the front (ie 800w)as this is the output, but look on the plaate at the rear as this will give you the input wattage.
