Lots of people will say you should be careful with plastic but I never have been !Hi, Basildog what did you use to clean the loo ?
I stopped using the pink years ago as it turns the separate toilet tanks blackAquakem Pink rinse in the flush water.. OR if the flush water comes from the main tank as our's does, keep a spay bottle with diluted 'Pink" to use after flushing..
keeps the bowl clean and slippy and according to the label, it leaves a protective layer to stop the build-up of bacteria.
Bowl will still need cleaning occasionally, only use plastic safe cleaners.. these are generally labeled 'green' products , usually citrus, but do check label.
or Thetfords own product , pricey but it does work
https://www.thetford-europe.com/product/toilet-bowl-cleaner/
It's probably the designer labels ...................as they seem to look very it
Bloody spellcheckerIt's probably the designer labels ...................
we use happy bowl liners
+1we use happy bowl liners
Have discovered bowl liners.
Work a treat!
+1I’m another fan of happy bowls!! Also keep a spray bottle of the ‘pink’ by the side of the loo and use every other day approx.
That's what I've been doing till now. .but polished it's whoosh fastest jobby in the WestI just clean the bowl with a baby wipe each day...... out last loo looked like new at 3 years and over 600 nights away
The Clingons are historyThat's what I've been doing till now. .but polished it's whoosh fastest jobby in the West
just remember its a big job(bie)Blimey. Never thought of wax polishing the bog!
Must add it to the wife’s job list.
Glad your flaps still opening JockWe have moved away from the spray bottle with a diluted Thetford Pink solution, as even with that correctly diluted, over time urine staining of the bowl was still apparent.
We now use a diluted citric acid mix in the same spray bottle, and have done for about a year now. As a result, the need for things like cream cleanser and Thetford's bowl cleaner (expensive) is very rare.
I can't comment on the "slip sliding away" bit, as our usage is the same as @scotjimland's, ie, flap open and bombs away, with the SOG expelling the odours.
Cheers,
Jock.
