Peugeot rear view mirror (2 Viewers)
Jul 17, 2009
188
155
I knocked off the rear view mirror on our old MH with my elbow and never replaced it, no point didn't have a camera fitted. Just done the very same thing to our new 2016 Peugeot MH which does have a camera and the screen is mounted on the mirror.
Does anyone know how to replace it, there is a hexagonal bolt on the windscreen but I fail to see how the two fit together and I don't want to force anything.
Someone else must have wild elbows like me, I can't be the only one !
11,956
16,570
A photo might be useful although interior mirrors are designed to 'break' off their mountings if struck - which usually means a similar amount of force is needed to replace them.
JFD
Apr 9, 2015
392
238
Crawley Down, West Sussex, UK
Pilote Aventura G730
since 2014!
Maybe there's still something on the floor of the cab that goes between the hex bolt and the bit in your hand?? :))
smiffy502000
249
124
sutton coldfield
coach built.
on mine you just hold the unit vertical over the mount then turn it 90 degrees to the right , it may be the same. mine is a boxer also.
motorhomewave
Jul 17, 2009
188
155
Thanks for those. Have attached 2 pics, I think perhaps smiffy you might have the answer, turn to right seems like it might work, will try when the big man turns on more light this morning !
motorhomewave
Jul 17, 2009
188
155
Success ! I knew you wouldn't let me down, thanks Smiffy.
Delboy157
Brilliant, smiffy50200. I had exactly the same problem and couldn't see how to re-fix the mirror until I read your post - thanks very much for the advice
smiffy502000
249
124
sutton coldfield
coach built.
hi, you are most welcome, glad it was of use . the only reason i found out myself when i had a new windscreen fitted on a peugeot 308 . the guy who fitted the screen showed me , cheers
WESTY66
5,837
14,291
South Yorkshire
Carthago Chic C-Line
All the gear, and no idea!
Thanks for that, I knocked mine off a few weeks ago and I put mine back via BFI (Brute Force and Ignorance) I thought it just snapped back on:eek::eek::eek:.
Manannan
Majestic 255
Since Feb 18
I found this forum after a google search, having knocked my mirror off. Couldn’t see any way to re-fit it, pushing it back on wasn’t working. Thanks for the info, still helping people Year’s later
JamSplat
coach built low prof
I'm partner knocked our mirror off recently, thanks to your help he managed to fix it without breaking the windowscreen
