Vic. Parsons.
A few months ago I set about turning our Oyster satalite dish into a sun tracking solar panel.
I first made a bracket to replace the original dish bracket and mounted the 80 watt panel.
I had to wait until we were in Portugal to meet up with electronics wizz Grant Needham who had made and programmed a new controller to fit the original Oyster wiring harness. This is a prototype with power switch, 2 button menu and small LCD screen.
The next picture is Grant wiring up the controller. (The case is made from an old cigar box).
On the panel bracket we fitted a light sensing diode in a deep tube but later added a piece of 45 degree cut tube to act as a deflector to prevent stray light reflected off the roof from giving false readings. (This can be seen at bottom right in the videos).
There were a number of small programming glitches when we first tested it, but over the course of a few days we managed to iron out the problems and it's now working perfectly.
The functions are:
Auto:
Find the sun, which deploys the panel and uses the diode and dithering to accurately locate the sun.
Next, it does a 5 degree clockwise turn every 20 minutes also with a dithering function to account for the sun's arc. The LCD displays a countdown to the next operation.
Park:
This will bring the panel down to the parked position.
This function also works when the ignition is turned to start the engine.
We're also going to add a park when dark feature.
Manual:
This allows individual button presses for up, down, clockwise and anti-clockwise with a 5 degree shift for each press.
There is also a setup menu and a voltage readout for the light sensing resistor.
We're now working on a second prototype which will work on a bluetooth connection to a smart phone with an app to control all the above functions so that the control unit can be hidden away in a cupboard instead of being surface mounted.
We're also thinking of making a kit for DIY installations which will include the panel bracket, controller and app along with full installation instructions.
This won't happen until we return to the UK next year but if you're interested in a conversion then PM me and I'll add you to the list of Interested parties.
Thanks for taking the time to have a look and hope it gives you some ideas as to what to do with an old satalite dish when other forms of tv reception eventually make it redundant. It's also a good alternative to removing an Oyster dish which has been known to be a difficult process. ?
The functions are:
Auto:
Park:
Manual:
