Omni-step not returning (2 Viewers)
KevinPowell
5
swindon
Auto trail apache se
Hi I have just bought myself a Auto trail Apache se 2007 , On buying it the seller said the omni-step was stuck out and it was a little fix to sort it, well after changing the EM50 box behind the drivers set this still did not work ,then I took a look under the step and released the arm from the motor that attaches to the step and the motor worked but only one way, has this got a retractable relay hidden some where as I have looked everywhere and can't find a thing, or am I looking for the wrong thing ?
please help
tonka
10,834
21,544
Cannock, Staffs
A class Burstner 800
Since 2000
Doing web searches you will find this a common issue and some relating just to Autotrail.
Here are some pointers.
1. Dirty step, they attract lots of road dirt so can get clocked and need a good clean and greasing.
2. Low habitation battery can stop the step from retracting.
3. Faulty micro switch on the step.
4. Polyfuse. Was an issue at a certain time with the Sargent units. The fuse fitted were from a faulty batch and needs a replacement.
Hope that helps.
Jul 29, 2013
9,071
18,565
Salisbury
Hymer B678DL A class
Could be the nylon gear cogs stripped in motoršŸ˜Š
Jan 11, 2010
2,749
9,583
Chester
Auto-trail
As said above because of it's location on the Apache the step will collect all the road grime, I did chat with one of Autotrail's CEO's asking why they didn't retract the step into a box to protect the wiring and workings, we'll look at it was the reply, as that chat was 12 years ago it must be some chat as they still haven't fitted any protection.
I fitted protection around our step and have never had any problems, I would suggest checking the whole system out starting with the obvious ie Step mechanism, the electrical connection under the motorhome, unless the hab battery is totally flat I would expect the step to move if only a little.
irnbru
13,514
31,142
Glasgow
Benimar 264
11 yrs
It happened to ours in France, It was a little switch under the step that needed cleaned.
Dec 24, 2014
9,225
47,648
Hurstpierpoint. Mid Sussex.
Compass Navigator
Retract it asap even if only by bodging.
Mine's manual and I forgot to retract it in the Cotswolds. Had to move close to the side in a narrow lane. It caught a roadside obstruction that tore it away and made one heck of a mess of the m/h's lower skirt.
K
KevinPowell
5
swindon
Hi Guys I have put a new polyfused unit in and also checked the gears there fine, does the micro switch tell the motor to retract ? step goes out on pressing button in Entry point but does not fold back in ?
Two on Tour
10,335
51,059
Elddis Autoquest 175
Check the micro switch with a multi meter. If it does not open and close and remains in open circuit condition then power can not be applied to the motor to retract the step.
Jun 8, 2019
4,931
18,760
Bexley Kent
Given up Motorhoming
May 2019
What happens if you half put the step out can you retract it. The reason I ask is perhaps there is a perimeter micro switch
K
KevinPowell
5
swindon
Hi Vic when disconnected the arm from the step of the the step motor then you can fold the step back in manually then connect the arm back onto the motor press the button and it goes out but does not return back in if that makes sense
cheers
Jun 8, 2019
4,931
18,760
Bexley Kent
May 2019
Sounds like a faulty M/S
Have you disconnected the arm from the step and see if the arm retracts?if it does make sure that there is nothing jamming the step from returning.
K
KevinPowell
5
swindon
Hi does anybody know where I can get a micro switch for a Omni-step Please šŸ˜‰
Two on Tour
10,335
51,059
