- Feb 24, 2013
- 13,054
- 101,383
- Hymer S800
- not long enough
we swapped our fridge for a massive unit that replaces the full height of the Tec tower with a 2 section fridge
The lower section is a pull out drawer designed to hold bottles upright, it is cooled by fans in the upper section blowing air downwards, that is the only cooling option but it seems very efficient I have checked it at 3C on 2 occasions
The problem in ours is the fan is noisy, not all the time but more often than not, sounds a bit like a computer fan about to pack in
I had thought it was a design issue with food pushing against the back plate, today I have taken the back panel off fir a look
My theory on computer fans would seem well founded but my theory of pressure from back plate is unfounded
But by sheer luck when I pulled the back plate off the noise stopped, both fans are now spinning but they are the most feeble things ever, no doubt will need to be changed annually or more often so I have not screwed the plate back on so I can have easy access when needed next
I will try and get a photo of the label on the fan
