Any advice is welcome, I am very new to this and am learning by reading.
Sorry for the long post but I want to give as much information as possible.
I have made some upgrades to the existing system:
I replaced the old PWM controler with:
A Victron MPPT 150 l 60 Tr (with upgrading in mind).
I have added:
A Victron Smart Battery Sense.
A Victron SmartShunt 1000A.
A Victron Cerbo GX.
I have the original 3 x 100AH Gell batteries, a split charge relay and a large fuse.
I have 2 (Missmatched) x 100w solar panels on the roof.
I have a 3000w inverter.
2 of the batteries are under the front seat. The third battery is under a seat in the lounge area, behing the front seat. The inverter us also under this lounge seat.
The controler is in the wardrobe, with the house fuse box, the shore power battery charger and the shore power trip fuse. About 2.5m to 3m away from the lounge seat.
The Smart Battery Sense and the Smart Shunt are showing 12.02v but when I put the multimeter on the Controller "Battery" connections, that is reading 13.3v.
The solar Watts have been low and the battery voltage has not gone above 12v very often (on the Victron displays). I'm too far from any AC, to plug in and give the batteries a good charge.
Earlier I was concerned that the battery voltage was too low, so I started the engine.
It seemed that the controler liked that and all of a sudden, the solar Watts came up and it was charging the batteries.
When I turned the engine off, it went back to normal, with low solar Watts and little charging, although the batteries have more volts.
I'm thinking that there is a cable problem. I could understand the controler reading less volts but reading more is very confusing.
So..... My idea is: to move everything to the garage. Where the house fuse box and the controler are now, is the other side of the garage wall, so no problem of lengthening cables.
With everything re positioned and new cables run, I want to add 600AH of lifepo4 batteries and 800w to 1000w of solar panels.
I live in the camper, full time, in Mallorca, Spain. We get a lot of sun and I think that this set up will give me enough power, to run the basics and some luxuries.
I will not be using shore power very often but I want to add this as part of the system. Obviously I will have to consider a B2B also, maybe 2 x Orion Tr Smart 12/12 30A.
I was looking at the Victron Multiplus - || 12/3000/120-32 but I'm not sure that I need that much. It does seem to keep everything in the same box and obviously it's a reliable make. And then I can sell my inverter.
I would have to do the repower in stages, so as to not be without power of any kind.
So...... I was thinking, that I should find a reasonable source for 600AH of batteries. Fit them in the garage and prepare the space for the equipment
Them transfer the new Victron equipment and the inverter into the garage and connect to the house fuse box's.
Then re locate the house fuse box's.
Then run a new cable from the alternator and put the split charger with the batteries.
Then save to buy any extra equipment needed and the new solar panels.
The only cables longer than 1m will be the solar panel cables, that are already the other side of the wall and the new cable from the alternator, from the front to the back of the campervan.
What opinions have you guys and girls got? And please be gentle.!!!
I have added:
A Victron Cerbo GX.
