stewartwebr
- Jun 6, 2010
- 1,110
- 3,423
- Morelo Empire Liner
- 36 years and 16 motorhomes
I was going to post this in the MORELO section but we don't have one
Whilst in the van a few weeks ago I noticed that the trim on the outer edge of the lighting pelmet which runs almost all the way around the van, the section above the drivers seat had a gap where the two edges join together. Further inspection revealed that most, if not all of this trim has started to shrink. Where the trim ends at a bulkhead or cupboard the gap is about 4mm but when two pieces of trim meet the gap is obviously double at 8mm. It has basically shrunk and gaps have opened up.
I took some pictures and sent the off to MORELO and Premium Motorhomes. I got a reply back from MORELO thanking me for getting in touch and stating that this is known issue but I will be pleased to hear that the issue has now been resolved and that all current MORELOS leaving the factory have had a design spec change and the issue resolved. Therefore the issue will no longer be a problem. They are proud to announce a number of new layouts for 2018 and continue to increase production of the MORELO brand. It read as if I was being dismissed and because they knew about it and it has been fixed on new vans it was no longer an issue. They did go onto say that my supplying dealer MAY be able to assist with MY issue.
Premium Motorhomes have come back asking me to take measurements and photographs. I had already send photographs to the MD but obviously he is far to important to forward them onto his team and it is every joint in the trim so MORELO must be aware of how much trim is required for a particular model.
Interestingly, not one of the e-mails mentions apology or regret for the issue from either MORELO of Premium.
I am less than impressed to say the least, not with the issue but with the flippant response from MORELO and the follow up from Premium Motorhomes.
These are the images of the shrinkage.
