KIPOR repair (2 Viewers)
Droop
20
Does anyone know where I can:
a) get my KIPOR IG1000 repaired - it will not start and/or
b) get an independant report regarding it's condition.
I would like to do (b) as the retailer refuses to repair it although at the time I had had it less then a year and used it for less than 20hrs.
I live near Reading, Berkshire, so somewhere local would be best.
Geo
Trader - Funster
Jul 29, 2007
11,757
14,565
Mansfield,Notts
Autotrail Tracker FB
45 +years with breaks
A weak spot on the kippor is the On/ Off switch, if it cant be switched on it wont start:Doh:
more interestingly is why your retailer thinks he has no obligation to repair or replace it
He has to do one or the other, eevn if it is out of gaurantee there is the expected life of the thing to concider:Sad:
45eEver
267
Mine refused to start after it had been laid up for the winter.
I couldn't find a thing wrong with it.
Spark, fuel, and compression all OK.
Sometimes valves stick open after their stems have had the winter to rust.
They should be left on compression.
I gave it a few pulls to splash some oil round it.
Gave it a squirt of "Easy Start"
Switched on.
Pulled.
It fired and ran like a good 'un, and has started easily since then.
Sundowners
3,289
3,571
Suffolk/Central Portugal
37 years
I had the same trouble, wouldn't start. My problem happened to be the float needle stuck in the closed position, I thought it was lack of spark because the spark seemed VERY weak.
But with a little patience and the help of a friend who seemed to know something about small motors, we discovered the float chamber empty.
It's not a big job to do, but you need to do it at a workable height and not on the ground in the rain as I did at a show we were trading at.
Now if it doesn't start, before taking it apart, I roll it around a lot quite aggressively until I think the needle frees, so far success everytime.
I am trying with a LITLE two stroke oil in the petrol to see if this stops it sticking, so far no sticking, but only used it twice since.
Nigel
Road Runner
1,143
1,445
Europe
yes
Since before Motorhomefun
Have you checked the oil level as they wont run if its low.
Eddievanbitz son is a retailer and possibly a repairer
Tinyk
83
Simon Jones, Planet Generators 01823-271935
Not used him but seems a few have and they are kipor agents, they also do lpg conversions for most makes.
Give him a try if your stuck.
Kevin
Mike C.
generator kipor repair
Petrol gets bad after some months.
I use Aspen petrol now. They claim it stays good for 5 years and doesn't gum the carburetor. Also it doesn"t smell .
Anyone also experience with this petrol
43,330
49,483
think at these prices i'll stick to the stuff we've used for ever.....real smelly petrol.
Aspen 4T alkylate petrol 1 litre bottle £2.86
Aspen 4T alkylate petrol 5 litre can £13.65
Aspen 4T alkylate petrol 200 litre drum £520.92
:Eeek:
45eEver
267
Sundowner, you said you use a little two stroke in your petrol.
Adding oil to your petrol increases it's viscosity.
Increased petrol viscosity weakens your mixture.
I suggest you keep an eye on your plugs and richen your mixture if accordingly.
haganap
12,760
26,461
planet earth
Niesman+Bischoff 79e
I'm an oldbie MH number 10
Im sure your point is valid or in anycase was valid some years ago. And I stand to be corrected but Is it not the case that in this day and age with the lowsulpher and environment changes to petrol, adding a drop of oil in to the mix won't do that? I know that that is certainly the case in diesel but wonder if this is correct for petrol./
45eEver
267
The viscosity of diesel isn't important as long as the pump drive will handle it Haganap.
Ditto fuel injection on petrol engines.
Injected engines works by volume.
Petrol viscosity is one of the things that regulates fuel mixture from carburettors.
It depends how much oil you consider a little.
And how well you mix it with the petrol.
A little oil added to the tank, can make the fuel at the bottom very viscous.
Checking your plug is cheap insurance against a risk that's difficult to quantify.
I'll be quite happy if you ignore what I said.
D
Droop
20
Dodgy retailer
They say I would need to prove it wasn't misused. How does one do that with a generator?
Planetgen
75
Taunton
RV
Hi Guys, please feel free to give me a call. I will try and help out. Good chance the Kipors need a service. I have just recently dropped Kipor for various reasons. We can service/fix them not a problem. Number is 01823 271935.
Simon (Planet Gen (Eddie vanbitz's son!)) :Cool:
jhorsf
9,130
8,045
DERBYSHIRE
ih oregon
perhaps you would like to name and shame the wonderful dealer with this fantastic after sales service as i for one would love to know where to vote with the wallet and avoid such a criminal response you got to a request for help in the short time you had had the genny.
:Doh:
markymark
241
25
New Forest Southampton
Swift 6 berth Coach built
I would be very intrested as i am about to get a IG2600.
Doing some research and the after care seems crap from the dealers and this problem with the start stop switch does not sound good. It creeps up a lot on other sites as well.
I cannot find a dealer near Southampton where i can go in and buy 1 face to face and if there is any problems i can take it back to him. Dont fancy buying from internet but dont have much of a choice
Planetgen
75
Taunton
RV
Hello, before you buy, give me a call. May be able to point you in the right direction. Maybe even save you a few pounds!
Si:thumb:
D
Droop
20
KMS Distributors
Sorry for the late reply on this.
The retailer I would wholeheartedly say stay well clear of is KMS Distributors , they are based in Essex. They have their own site. KMS Direct, Generators, Trampolines, Inflatable Pools, Tooling and Car Lifting Gear
and they also sell on ebay ( kmsdirectshops ).
Shows you can't trust an ebay powerseller. Sure they have plenty of positive comments but they get them for delivery and items that turn up and work. It's too late to change your feedback once things start to go wrong and their true attitude begins to show.
