Inverter issue (1 Viewer)
Scotchgitt
Van conversion
3 years
I have a 2000w sine wave inverter. 4000peak
When I turn on my coffee pod machine 1300w the low voltage trips
I have 2 210ah batteries in parallel and it still trips. Sits at 12.4 v with no load then drops below 10.7 low voltage.
Batteries are healthy and fully charged
When I run the engine and the voltage sits at 13.5v it works fine.
Can I fool the low voltage so I don’t have to run the engine?
Do I build a 2v lithium cell to add in series to compensate?
I used to use a cheap non sine wave and it all worked ok until the inverter stopped working.
SuperMike
2,477
7,593
St Albans
Winnebago Sightseer
Batteries phutttt. 12.4v is not fully charged. 1300w would be a challenge for healthy fully charged batteries. :gum:
19,454
30,690
I agree that the batteries might not be in the best of health, also how far away is the inverter from the batteries and what size cable? when we first got our van it similar issues but that was caused by close to 8 metres of cable between batteries and inverter.
53,764
151,290
Maybe your cables to the inverter are too small, if the cables aren't up to it you will get a volt drop across them.
What size are your cables?
At the very minium I would think you need 35 mm sq cables.
53,764
151,290
No way are the batteries are healthy and fully charged at that voltage, fully charged they should be an absolute min of 12.7 normally on a good battery 12.8 to 13.2v.
May 7, 2016
7,309
11,818
West Sussex
Malibu Van 640 LE K
Since 2003
As batteries age they can lose capacity through sulphation. Basically this clogs up parts of the plates, leaving a small area to do all the work. This means that a battery that started off life as 100Ah might be performing at say a 30Ah level. The bit that is working may still charge up to the usual voltage and appear healthy until you ask too much of it. Think of it like a toilet cistern full of bricks, it will fill up and appear full but won’t flush the toilet properly.
Zigisla
2,584
3,111
Gosport, Hants
Sunlight A72
I had the same thing on my first set of batteries. Sat at 12.6v thinking they were fine until you switched any load on, then they dropped. Switch on the inverter and they plummeted and tripped the low voltage cct off. Replaced batteries and all was well - for 18 months anyway.:rolleyes::rolleyes:
S
Scotchgitt
Van conversion
3 years
Thanks for the replies.
I will do some more research. They are solar charge only and the solar charge control box is saying they are full.
I will dig out the multi meter.
I have a split charge relay to fit so it will charge when I’m driving and the inverter has a built in charger so once I have tested the before voltage I can do some experimenting.
I have new solar panels and controller on my todo list all ready to fit
The inverter is 500mm away from the battery.
53,764
151,290
If the solar is connected you will be reading the solar regulator voltage not the battery. To get an idea of the battery voltage you need to disconnect the solar, or cover the panels, or do it at night. Let the batteries settle for an hour before taking a reading.
19,454
30,690
If your batteries are no 12.7 a couple of hours after the sun goes down they were not fully charged.
