Hi Antique from another Antique! (Well at least we increase in value.Just a word to the wise Saltings.
Before removing the drivers seat, make sure you un-couple the srs electric connection below the seat.(with ignition off).
From experience they break easily!
Hi JohnOn our 2017 based Fiat, you need to remove the plastic sides and rear.
Take the cap screws out front and rear, there is what looks like welds on the seat base frame and underneath there are 2 13mm nuts which you need to remove and at the rear on the passenger side of the seat frame is a thin flat bolt which is the swivel stop this needs removing. Disconnect the wiring looms under the seat and it will lift out and its heavy believe me.
John.
Thanks for the input.We have 3 Allen key bolts running down either side of the complete captains chair assembly with no need to remove plastic side mouldings (Just a thought)
And ...
I'd be damn careful with that battery and it's charging
