How Should A Benimar's Doors Lock? (2 Viewers)
HKF
2,144
4,415
The Charente, France
Benimar Europe 740
Since August 2021
We have a new-to-us Benimar but I'm confused by the locking mechanisms. On the key remote, there are three buttons; top one showing a key on the cab doors, middle one showing a padlock and bottom one showing a key on what looks like the back of the MoHo. If I press the top one, it unlocks the cab doors. If I press the middle one, it locks the cab doors quite noisily. If I press the bottom one, it makes a quieter double click on the cab doors. Nothing at all happens with the hab door. The only way I can lock / unlock the hab door is with it's own key. However, this only locks it with the sliding up and down thing and does nothing with the two big bolts. What is the point of the two big bolts on the hab door if they don't do anything?
Can someone please explain to me what's supposed to happen, as I just can't get my around it!! :unsure: :rolleyes: Thank you so much!
Howard H
4,832
4,795
West Lancashire
Benimar mileo 294
No that’s correct the bottom button is for the side and rear doors of a van, on our Benimar you have to manually lock and unlock the Hab door 👍
Sorry don’t know about the two bolts 🤔
HKF
HKF
2,144
4,415
Benimar Europe 740
Since August 2021
I don't have any rear doors....only the garage ones on a small key lock.
Sep 17, 2017
5,484
10,235
Birmingham, UK
A-Class
Not all vans have central locking. If it does, the top button open the cab, the middle button locks everything and the bottom button opens the hab (or rear/side doors on a PVC). Even if you press to unlock the cab button, you may still hear the solenoids move in the hab door... mine also does it. Not sure why though.
If it's like ours, it won't engage the locking pins unless the door is latched closed. With the door open, flick the latch catch across so it thinks it's closed. The the fob should lock it... but remember to pull the handle on the door to open the latch and pins before you try to close the door!
Sep 17, 2017
5,484
10,235
Birmingham, UK
A-Class
Inside a hab door mechanism from a Ducato based van. The latch moves the threaded rod to activate the microswitch. That's how it knows if the door is closed or not. It won't try to lock until the latch is closed.
irnbru
13,514
31,142
Glasgow
Benimar 264
11 yrs
There is no central locking for the hab door, You either lock it from the outside with a key or press the top catch down from inside to lock it. What model did you buy? The top unlocks the cab doors on my remote and middle locks them.
HKF
HKF
2,144
4,415
Benimar Europe 740
Since August 2021
Hi. We bought a Europe 740 :)
