How much water for a MH shower? (1 Viewer)
Feb 27, 2017
28
16
Oxford, UK
A/S Bourton
Three years and still learning
Bit of a random question I guess. I've been looking at fresh and waste water capacities on various MH's and trying to reconcile how useful they are. Basically I expect that if the shower is used then water usage goes up and trips to get more fresh water and dump grey go up. Before I research this by taking an actual shower does anyone have any thoughts on how many litres of water might it take to do the necessary and have a half decent shower?
Dec 10, 2013
3,423
12,231
South Staffs
Pilote P740GJ
Since 2013
I find it depends if you are a teenager or a pensioner. :)
Oct 2, 2008
4,471
7,957
Salopia
Duro 6x6 Overlander
since 1968
I find male or female ! I'm a squirt soap squirt rather than her wash away the sins of all humanity , so an average would be hard to guess :LOL:
May 7, 2013
845
1,353
RUK
On our 2nd MH now a AutoTrail Savannah which we're absolutely delighted with
How dirty are you really??
Lenny HB
53,431
150,019
On the coast in West Sussex
Hymer B678 DL
Don't know about an individual shower but with both of us having a shower, & everything else water is used for our daily useage is around 35Lt.
Nov 3, 2016
881
1,679
Derbyshire, UK
Bailey Autograph
Since 2016
My fresh water is 80l and I recon I can get 4 showers and daily drinking water and toilet flushing from that by myself (4 days use) so I guess in the region of 15-18l per shower.
Thats using the technique of getting it to the right temp. wetting me down well. Turn off and do the soap part then rinse off afterwards.
43,329
49,446
Depends on the boiler capacity and how hot you like the water.
A 10ltr boiler may give you 15 litres of shower water....enough if you use the shower properly....you can't use it as you do at home as there just isn't enough hot water.
1..get wet, turn shower off
2..get soapy
3..turn on and rinse off soap.
Takes more than you think to do that.
The same shower at home may use 40 or 50 litres of water.
Feb 14, 2009
1,373
3,325
Chandlers Ford, Hampshire
Burstner TD700 H L
Since 2008
Found this on a caravan ( sorry ) web site ..:sleep: may be a guide
I use the shower in mine all the time. Use it for a quick wake up shower first thing in the morning. Although I now make sure there's plenty of water in the Aquaroll the night before. ......yes I did learn the hard way
I only manage to use about 15-20 litres of water
oxoaps
Feb 27, 2017
28
16
Oxford, UK
A/S Bourton
Hmmm - I'm a pensioner who thinks he's a teenager! Lot's of good feedback here - thanks guys
SuperMike
2,477
7,593
St Albans
Winnebago Sightseer
Management will use a good half of an 85g tank, more if we are hair washing as well. She has to shower with Dermol and rinsing it off takes time. o_O
Dec 23, 2014
2,178
2,817
South Somerset
Carthago C-Line I 50
Since 2009
Can't give a guide about showers alone but we work on 40 Ltrs per day for two. That includes a showers each toilet flushing and all other incidentals such as washing up, pots of tea, cups of coffee, etc.
PS. Our water pump delivers 7 Ltrs a minute and we both comfortably shower in less than three minutes.
Bart
3,188
1,398
Northern Ireland
Boxer L4H2 van build
Since 2016
we find we use about <10 ltrs per shower using the get wet then turn of the shower , lather up , then get shower / rinsed.
Reactions: f6c
TCG
Jul 6, 2017
1,358
2,042
Salford Priors
Autotrail Delaware
would agree with that, tank top up every two days
The Nomad
1,052
1,064
Wandering in Europe
Overcab
Many years
We wildcamp/use Aires a LOT and so need to be careful with onboard water.
I've done the trick of taking shower head apart and applied a bead of silicone to the inside face of the biggest 3 rings of holes, thus leaving just 2 rings of holes for water to pass through.
Remarkably, that still really does leave easily enough jets to wet you/wash hair etc perfectly adequately.
We also do the water on/off through the showering cycle: on to wet hair, stop whilst lathering, on to rinse and wet body then stop again whilst lathering, then on again to rinse.
We both shower daily in the MH, but through these methods use only 2 or 3 litres of water per person per shower.
Alistair33
1,079
3,258
North Yorkshire
Hymer
None
Ours lasts three days, same as the toilet cassette coincidentally!
Duck Truck
1,203
1,226
UP North
Hobby 725
since 2012
Try sharing the shower
it halfs the water used unless you get carried away :D
Minxy
32,656
66,560
E Yorks
Carthago Compactline
It also depends on what you use to wash with, some shower gels are a beggar to rinse off so I prefer a good old bar of soap and an 'all in one' shampoo.
hilldweller
605
36,109
Macclesfield
Zilch Mk1
From Aug 2007
There is another side to this, hot water volume, your heater will heat it's smallish tank up but relatively slowly so you will run out of hot water before you run out of water. You'll have to suck it and see. I laugh, quietly to myself, when I hear people say "I would not use a campsite shower, our MH shower is good for us". They obviously don't know what a real shower is like. Many of us describe a campsite by the quality of their showers.
SuperMike
2,477
7,593
St Albans
Winnebago Sightseer
Jan 26, 2017
3,474
11,741
Mid Suffolk.
Autosleeper Inca
Eight Years and 28,000 Miles.
Our hot water boiler holds 12 litres, which is more important than the total amount of water carried.. we manage two showers before the hot water runs out.
SuperMike
2,477
7,593
St Albans
Winnebago Sightseer
:eek: That's over 190 Ltrs per shower :Eeek:.
Yep. Dermol is soap substitute for skin conditions and it is a bugger to rinse off. It is water soluble, but takes time. Good job the grey tank can cope and the water heater is 10gals, which almost keeps up with her if on electric and gas. Management likes the water cool, so it all works well. :)
two
Aug 4, 2011
4,903
4,573
West Midlands
A-Class Fiat
Depends how far it is to the shower block
