High Brake Light (1 Viewer)
Sep 13, 2018
168
167
Ludlow, UK
elddis 105 2015
before this it was in the 90 s
Morning,
Elddis 2015 105
The high brake light has stopped working at the rear so question is: is it a simple job to replace I have been told that it is a sealed unit?
And also if this has happened to anyone what was the cost to buy a replacement?
Many Thanks
Feb 22, 2011
9,796
20,164
Newcastle under Lyme
Hymer B544 A Class
I bought a replacement for mine from ebay then fitted it with led's as it came with halogens. This was a Hella unit.
A photo might help
D
Sep 13, 2018
168
167
Ludlow, UK
elddis 105 2015
Thanks for reply, mine are halogens apparently and was yours a sealed unit?
Jan 19, 2014
9,395
24,784
Derbyshire
Elddis Accordo 105
since 2014
Ours has gone very brittle with lots of cracks in it. Just removed it, had to lever it off the sealant where the wires go through, there is no play in the wires and fortunately they've snapped off the LED board so there's 10mm sticking out the van to solder onto.
Just tested the strip and only half of them work anyway, there's a couple of rotten smd resisters open.
I've seen the JOKON replacements on ebay at Ā£48 šŸ˜³ JOKE-ON šŸ˜
Ordered a Ā£10.99 one that gets a couple of good reviews on amazon. It's bigger than the original so will cover up the whole of the indentation where the old one sat, old silicone and any holes.
Jan 19, 2014
9,395
24,784
Derbyshire
Elddis Accordo 105
since 2014
New one arrived, seems OK, tested it with the old one to compare brightness..
They're surface mount LEDs
I'll have a look at fitting it after lunch, there's a stub on the back needs taking off first.
Jan 19, 2014
9,395
24,784
Derbyshire
Elddis Accordo 105
since 2014
The capping has cracked where the cable goes through, don't think there's anything I can do with that šŸ¤” think it's only capping to make the joints look nice though.
