Hey all,
As you know - I am really new at this.
We took our brand new motorhome out to Pembrokeshire and then for a little run around Holland, Germany, Belgium and France at half term and really loved it - luckily we had no problems. That was Feb half term.
NOW HELP!
I am in the South of France and I am stuck! I first of all had an issue with the water just emptying - apparently after some research I found out this was due to an anti freezing something or other and I had to click something to stop it spewing out the bottom. That was not too bad as it was in Ashford just before I went to the shuttle.
Now I am near St Tropez and having constant heating/water issues. The Truma system keep dishing out the warning codes (which are not in the book and are not on-line - of course they have not emailed back). So I was having plain sailing just going from aire to aire not hooking up as I was running of solar power and just topping up the water. I arrived at an aire with hook up and that's when it started. I keep getting 'E632 H'. I called the dealership and apparently this is due to the aires wiring and not to use it so it tripped the system (I was talked through the reset task on the main unit under the seating area). But now even not being hooked up its saying it. Any ideas? And also I keep getting various other ones.
Stressed dad of two flying solo until Saturday
Rich
NOW HELP!
Rich
