Ground clearance (3 Viewers)
Phil56
14
8
Worcestershire
Hymer B654
Still searching for the ideal motorhome for a year in Europe/Morocco with self, wife and dog! Following advice on this forum I've drawn up my list of essential and desirable specs and have spent hours wandering around dealers looking at different types of van. Seen several that almost fit the bill - but, I guess like everything, it all seems to involve compromise. Two in particular seem OK. One was a Hymer A Class. But, to my untutored eye, it had almost no ground clearance beneath the van. The end of the exhaust was probably no more than an inch off the deck, and the rest of the van not much higher. I'm told it is because it has a 'double' floor for insulation purposes. But I'm not sure you could take this anywhere off a black top road; could even be a struggle to get onto campsites, I think. Another van had better ground clearance but had a large garage (which we want) with a huge (it seemed to me) overhang at the rear. I'm not even sure you could get it up a ramp to go on a ferry without the back of the van grounding.
That said, the people who design and make these things must know what they are doing. Is ground clearance something I should be worrying about? Maybe I am getting too stressed about going to Morocco? We don't intend to go wadi bashing, but it would be good to be able to access wild camping spots without leaving the exhaust and half the bottom behind.
I am new to this (first MH). Should I forget about ground clearance? Is it a non-issue?
Thanks,
Phil
Feb 9, 2008
4,094
5,915
SW Scotland
LP Coachbuilt
Never really thought about clearance. We get the occasional 'ding' from our exhaust tailpipe at the side. especially in car parks but never had a problem. Apart from the exhaust I can generally crawl anywhere I need underneath, never bashed a tank either come to think of it.
Rgds
Bill
P
Phil56
14
8
Worcestershire
Hymer B654
Thanks Bill. Should have said that the other van under consideration is a Swift Sundance 630G.
Wyaye wires
3,333
9,263
Berwickshire
A class Neisman Bischoff
since July 2009
We have a Burstner Elegance 821i with a large overhang, so like our previous van we had air suspension fitted for ferry ramps etc. Inflate and no problems, so far! ::bigsmile:
Biggest problem I've found, on rough ground, is that being front wheel drive you can get 'beached' :Blush: It happened in our previous van and again in Ireland with this one. :Blush:
But don't tell Laneside.:helpsos: That's how I came to be known as 'Tow Truck Freeman' :ROFLMAO:
19,376
30,366
We have loads of ground clearance I can crawl underneath without jack no problem, generally you get more when the MH is built on RWD chassis, but then the other side of that is that the vehicle is quite hight. But you are right some do look very close to the ground.
JeanLuc
3,304
2,199
Warwickshire
Hymer B630 Star-Line
I agree that the ground clearance on some motorhomes look a bit on the 'mean side'. This is particularly the case with double-floored A-class vans built on the Alko 'bolt-on' chassis. It is noticeable in the case of the more recent B-SL (A-class) Hymers on a Fiat/Alko chassis. I have never heard of particular problems, but I can imagine one would not want to park over long dry grass in case of fire, and they might 'ground' on bumps.
As others have said, a RWD chassis will tend to have more ground clearance as there is only a single floor built above the original vehicle's chassis. The Alko system is an aluminium box frame with a floor above and below.
My Hymer Starline (Merc RWD chassis) has loads of ground clearance - I can crawl around underneath without putting it on ramps, although it seems to be getting a tighter fit as the years go by (I'm less flexible, not larger).
If you like the look of a Hymer A-class (called B-klasse) look for a B-Starline (or an S-class if affordable) - ideally pre-2006 as the earlier ones were very well made. Don't let anyone tell you that a single-floored Starline is not well winterised - they are! The waste tank is fully insulated and heated by the Truma warm air system; the fresh water tank is inboard. If you want a garage model, there are three Starlines that might suit: a B630 (like mine) at 6.41 metres; a B680 or B700 at 7.2 metres. The B680 is a longer version of the B630 layout (L-shaped settee, rear double bed over garage and front pull-down bed, whilst the B700 is a so-called 'Bar layout' with a third captain's chair behind a bar-table in the lounge area - front and rear bed layout is the same in all three.
5,944
39,076
Uk
We have no problem with ground clearance on our 2001 Hymer,ours is on the fiat chassis and not double floor. As you say the Alco chassis double floor hymers are low compared to fiat chassis.
P
Phil56
14
8
Worcestershire
Hymer B654
Thanks all. Especially grateful to Jean-Luc for the advice regarding Hymers. I do like the look of the B630. It ticks a lot of our boxes: the fixed rear bed, garage, reasonable lounge being key.
I am currently looking at a Swift Sundance 630G - a bigger beast at 7.13m. It also ticks most of the boxes, but I am getting hung up on the size of the rear overhang. It doesn't have air suspension, which I gather is a good way to firm up the ride and give a little more ground clearance to the rear. Nor does it have rear supports for when camping (if they are necessary?). As a newbie I was interested to read that although it has a cavernous garage and a large payload - you can't just load it up to the gunwales. You are likely to hit the max allowable rear axle weight long before you bulk out in the garage.
The RWD Merc engine and chassis on the B630 sounds good to me. Anybody know of one needing a new home? Jean Luc?
Thanks, Phillip
PS Thank God I paid my tenner....I think I've already asked my full entitlement of questions as a non-member!
JeanLuc
3,304
2,199
Warwickshire
Afraid not - it was our first motorhome in 2007 and we're planning to keep it for a long time yet. The B630 was available with 130 or 160 bhp engines. Most are on the 3xx chassis but a few were made on the 4xx. Depending on the engine they are designated 313/316 or 413/416 (ours is a 316 with a MAM of 3,800 kg). The larger Starlines (680/700) are on a 413/416 chassis with a MAM of 4,600 kg.
Unfortunately, Starlines are not very common and the B630 was particularly unusual in the UK. You will see many more abroad - the Dutch seemed to be keen on them. Have a look on mobil.de for an idea of what is available overseas.
824
2,066
bedford
I have a chieftain tag ,it has hydraulic levelling with wheels at the bottom of the legs. If you bottom out you send the legs down , lifting the body up and drive away:
Allanm
5,431
9,192
Cotes d'armor, France
Burstner Harmony TI 736 G
Since 1987
Plenty of room under ours too, as I have been finding out while lagging the water tanks and pipes, because Autosleeper think we will only use the vans on warm days!
We have a 7ft overhang and despite the Councils recent road resurfacing outside our house resulting in probably the steepest camber on a residential road anywhere, and a steep driveway, we have never been anywhere near grounding the van.
Allan
makems
3,440
27,723
Ingleby Barwick,,Teesside
Sadly had to give up
I am getting hung up on the size of the rear overhang. !
I have a Burstner Elegance with quite a considerable ovhang. After grounding the rear a few times getting on and off ferries I had some dolly wheels made up and fitted in Morocco for about ÂŁ100. See picture.
makems
3,440
27,723
Second attempt at pic!
18,035
48,142
My standard of ground clearance is obviously different to others. We took ours to Dartmoor soon after we got it. We went down lanes so narrow the vegetation was hitting both mirrors at the same time. Then we went over a proper humpbacked bridge with no problem, though we did breath in as we went over it.
We ended up at Fernworthy reservoir. If anyone thinks their van has good ground clearance challenge them to meet you there!
Not many mention Swift and Hymer in the same sentence. There seems to be no comparison in build quality if you read enough in here.
The Hymers should be renamed Tardis.
Ground clearance, I don't think anyone else has ever asked the question.
P
Phil56
14
8
Worcestershire
Hymer B654
Very true, Brian! Comparing Hymers and Swifts (on paper!) does seem a bit like comparing apples with oranges. So - just to further complicate things - does anyone have strong feelings about Elddis? I'm off to look at an Autoquest 155 today. On paper (must get out more!) it ticks a lot of our boxes. Just a bit concerned about adequate storage for an 8 month journey.
Have to say that I am very impressed/grateful for all the comments and feedback on here. It takes time to bang out a considered reply. Thanks.
Phil
maz
Jan 26, 2011
4,460
7,740
Bizeljsko, Slovenia
N+B Arto
Since March 2011
My van is on the Alko chassis and is quite low to the ground. This is because it is the 'speeding bullet' racing version. :winky:
So far I have not grounded on anything but I take it easy over speed humps. The van does not have an excessive overhang but it does have an under-slung spare wheel right at the back - which I make allowance for when coming off slopes. Haven't scraped it on the ground yet - but the potential is there. :RollEyes:
That was one thing we learned in Morocco, coming off wild camping areas, steep onto the road, you go diagonally so one wheel, one side lifts first. It worked.
However the adventurous ones don't mess about, they buy proper job MHs.
Phil
One thing we Olde Fartes have is time to type.
And the need to type, this retirement lark is harder than working, the day starts with "what do I do today ?" and in this grim weather typing is the only option.
JeanLuc
3,304
2,199
Warwickshire
Phil
Many people have them and are very satisfied. However, it all depends on what you are looking for. Elddis sits in the 'good value' British-made category. By comparison, the German and some French brands tend to be better built and longer-lasting. This is particularly true of the older models - say 2005 and earlier. So, brands like Hymer, Euramobil, Hobby, Burstner, Rapido, Pilote etc., and at the premium end, Concorde, Nieseman+Bischoff, RMB, will generally give you more for money if you buy second-hand compared to a new, or nearly new British van. Critically, the brands above will beat a British van 'hands down' for year-round use as the Brits are really designed for warm weather touring. They can be winterised, but it takes a bit of work, whereas one of the Germans / French will be built to take it.
1,944
2,923
Kent coast Hythe
Rapido fiat based
brought first van 16 yrs ago
[HI]this retirement lark is harder than working, the day starts with "what do I do today ?" and in this grim weather typing is the only option.
[HI]
agreed so far cleaned every aspect of the van for next Ski trip now rain has come retired to typing.:ROFLMAO:
