Note: This feature currently requires accessing the site using the built-in Safari browser.
I got alugas (great system BTW) and I’m sure I was instructed to just fill, don’t even have to open the locker door, just connect and fill
I was told to turn off with gaslow
We also have Alugas and were told to just fill, so I'm confused. How can you get gas into a bottle when the valve is shut?
The valve is on the outlet of the bottleWe also have Alugas and were told to just fill, so I'm confused. How can you get gas into a bottle when the valve is shut?
That sort of answers your question... as there isnt any difference between filling an underslung tank and refillable cylinders... ie you will most probably not have a problem if you dont shut the valve ...but best practice and advice seems to be to shut the valves..I had a lpg tank before and never had to close the tank when filling. Your thoughts pls
I have a bulk tank & turn off from the tank for the simple reason that I have to turn on , open, the inlet thumb wheel to allow gas into the tank from the remote filler. The inlet & outlet thumb wheels are positioned either side of the tank gauge.Hi never gaslow before heard different views do you turn the bottles off when filling or just leave them open. I had a lpg tank before and never had to close the tank when filling. Your thoughts pls
An engineer from Gaslow suggested this particular scenario to usI turn it off because I don't trust the garages to maintain their pumps properly. A dodgy pump could cause a surge or over pressure event that could in theory damage the regulator in such a manner as to allow full flow of gas into the van through the regulator.
I don't know this for a fact, but I am not prepared to take the chance so I turn off before filling.
As I always turn the bottles off when driving, and always drive to and from the filling station, the bottles are naturally turned off.
That accords with the advice received when the Alugas bottles were fitted.
Yep, wrong end of the stick.Errrr the system automatially turns the gas off when driving doesn't it and only switches on when you turn the hab systems back on
Or have I got the wrong end of the stick as unless my system switch is on we have no gas
It is only permissable to drive with the gas on if you have the Secumotion regulator together with either anti-rupture pigtails or bottles with anti-rupture valves.
The Secumotion regulator has a crash sensor which cuts of the gas in the event of an accident.
The anti-rupture pig tails/valves cut the gas off if the hose between the bottle & regulator ruptures.
How could it possibly cause damage to the regulator?Yes
Always thun off to prevent potential damage to the regulator
I was advised by the engineer from Gaslow to always turn off before filling due to potential damage to the regulatorHow could it possibly cause damage to the regulator?
The pump pressure can never exceed the working pressure of the bottle when in use so the pressure on the regulator will remain constant.
Never come across a system like that. If you have an underslung tank with electric cut off valve if would be possible wire it to do it.Ta @Lenny HB
No not totally got wrong end of stick got those just got the impression when the power goes off so does the gas will double check when we get Lockdown released the next time
Sorry if that's how it sounded, certainly wasn't intended but think about it.I was advised by the engineer from Gaslow to always turn off before filling due to potential damage to the regulator
Though I do bow to the superior knowledge of Funsters
A faulty pump was the reason he quotedSorry if that's how it sounded, certainly wasn't intended but think about it.
The pressure in the pump and pressure in the bottle have to be equal for the pump to stop dispensing if filling to capacity.
If the pump pressure was higher then it would have to increase the bottles pressure to auto stop and would override the 80% mechanism.
That increased pressure may damage the regulator.
Turning off the bottle will have no effect as the pump will still increase the bottles pressure beyond its normal working pressure to auto stop the pump.
Now you open the valve and release that increased pressure to the regulator anyway.
The only way damage could happen is if the pump was faulty and delivering an excessively high pressure.
But i covered that scenario.A faulty pump was the reason he quoted
As some pumps are not correctly calibrated
