Gas - How to? - Yet another newbie question (3 Viewers)
Tony68000
191
420
North Lincolnshire, UK
Rapido 999M
Super Newbie
Really aiming to get my money's worth from this forum, but thanks guys you have been SUPER helpful over the last few months...
Picking up my Rapido next week (or early the following week, depending on the weather). I've slowly got a rough idea of most areas, but GAS confuses me a little.
The dealer is putting in a couple of 'part-filled' gas bottles, but I can't imagine these lasting long, so will need to do an exchange sooner or later. This is the bit I'm unsure about.
Do I drive my MH to the gas dealer, or take the bottles out, put them in the back of the car and swap them that way?
I have no idea how to remove a gas bottle. I saw a YouTube video and they used a spanner to remove one, but then fitted it back hand-tight.
I also understand that most people turn the gas off when travelling, and don't rely on the 'gas safe' crash sensor. Sensible idea, or over cautious?
Your directions and tips would greatly appreciated.
Oh, one last query... do I cook, using gas in the van with doors and windows open, or is this safe with no 'ventilation' except the extractor fan?
The van has a carbon monoxide detector fitted, but I'll replace that as I'm not sure of the battery life, etc. They are quite cheap. Do you think 'lpg' detectors are a worthwhile investment?
(sorry, lot of questions, again) :)
Apr 9, 2018
8,643
44,653
Worcestershire
Bailey Adamo 75-4t
March 2018
If Calor or other removeable bottles take them to a dealer and swap them. In the moho or in your car. Remember, propane are left hand thread. Tighten with a gas spanner. Job done.
If you have a crash safe valve then you are ok to travel but most people just turn off the gas.
You may see a sticker near the oven advising opening a nearby window if cooking. The cooker, heater and fridge vent outside so no real reason to open doors or windows beyond the little bit of ventilation near the cooker.
Jan 8, 2013
8,490
11,530
Dronfield - Derbyshire
Burstner Lyseo 690G
Happy FLT since 2011
I used to change the gas bottles while away in the van - mostly at supermarkets (home and abroad) so there is no problem parking the van.
Gas bottles tend to need a large bottle spanner and are left hand threads
Cooking in the van is no problem but keep the detectors working.
Refillable bottles are a good investment if you find you are buying gas bottles regularly - Refillable gas is around a third of the price.
Dec 24, 2014
9,218
47,606
Hurstpierpoint. Mid Sussex.
Compass Navigator
Watch out for ( e.g. don't drop/lose) any 'O' rings or fibre washers when you remove/refit gas bottles.
You can use one of these spanners with your existing connector nut
or just buy one of these (the pink bit) that also fits over the existing nut. You won't need a spanner as you can tighten the connection just by hand.
or you can replace the complete pigtail (hose and connectors) with one having a hand tightening fitting.
1,732
2,770
East Yorkshire, UK
ADRIA Twin 640SLB
I had a Cobra lpg gas detector fitted that was integrated with my alarm & tracker. It also detected other gasses. I used it all the time when sited without problem and no detections. It did work as it picked up aerosol use on occasions. Expensive but reassuring peace of mind.
I once met a Brit on the continent in an old Hymer. He had a stand alone gas detector fitted when he bought the van fairly recently. It was well worth the expense as it detected a gas leak whilst they were away camping. I think they were asleep at the time but cannot be sure @fter the passage of years since we met😜
I don’t think many have them fitted though, probably down to cost
17,635
43,355
When fitting a gas cylinder, do it up tight as you can by hand then about half a turn with the spanner to seal. If you plan on using the van in colder months, you need to use propane (red usually) as butane does not move from liquid to gas at temperatures below about 5 degrees. So no heating or cooking with butane in winter. Buy a portable gas sniffer. Great for checking joints inside the van as well as the bottle. You can get a cheap one for about £20
If you plan to use the van a lot, consider a refillable gas system as the reduced price of gas at the pump is a huge saving on the likes of calor, and you don't hand back part full bottles to exchange for a full one. It's a huge con bottled lpg and there are plenty of pumps at petrol stations still despite what some think
43,330
49,486
Beats my why the dealer is fitting two part filled bottles.
Its usual to get at least one full bottle..
Removing bottle ...
turn off the bottles main valve, usually a round tap on the bottle top.
Using a spanner (unless it has a hand wheel) turn the hose nut CLOCKWISE....the opposite to what you would expect.
Undo any securing straps etc then lift out. They are heavier than they look.
Refitting is the reverse and just nip the hose nut....don't overtighten it, it doesn't need it.
942
3,141
Totton
Bailey Autograph 745
Since Sept 2020.
Don't assume swapping out the bottle for a full one will be straightforward, things may well have improved but even our main Calor Depot didn't have any to exchange a few weeks ago.
stevewagner
1,816
4,053
Pevensey Bay
Yonks
My cooker doesn’t vent externally
stevewagner
1,816
4,053
Pevensey Bay
Yonks
Ok, but it’s designed to be used in a motorhome and as I suggested they do recommend ventilation near the cooker when being used
I don’t believe it’s necessary and could be dangerous if opening a window that’s next to it.
