Gas hose (2 Viewers)
Mar 12, 2016
52
19
Jersey JE37YN
Profile
Hi,
would anyone know where I could get ( around the Heathrow area, or online perhaps ) a connector like this attached to a short length of gas hose, I need to fit a U.K. regulator?
Thanks.
Apr 22, 2018
6,827
12,599
Herts.
Adria Coral lowline
Isn’t that a “gas pig tail” so normally have fittings both ends. One for gas bottle and other to regulator. But I suppose you could just cut off the end you don’t need.
Gasit have a range of them
as do BES
MisterB
5,962
13,326
Adria 670 SLT
Any caravan or camping shop will have them on line or in store. Even B&Q might stock them
SandraL
1,373
985
Somerset
Hymer b694sl
Or Hamilton gas products do mail order.
Mayflower
Mar 12, 2016
52
19
Jersey JE37YN
Profile
Thanks all,
Well, I need to fit this so I can use a Calor gas bottle.
But it seems it’s a regulator too, so there would be two regulators in the line.
Not sure it would work like that.
Sep 10, 2012
2,139
3,799
worcester
Sunliving van
You need to change(exchange) the bottle u have for a standard calor propane bottle then a standard pigtail will connect it to the regulator shown in your photo.
bobandjanie
8,175
15,851
Javea, Spain
Pilote V600g
Hi, looking at your photo I can see you have a large Spanish propano bottle, have you actually got a UK gas bottle that the clip on regulator fits, because you have a regulator and in an ideal world a Calor 13kg propane and a new pig tail, so you just undo the hose you have marked and fit new hose and the replacement bottle. 👍
Without having to pay a deposit to Calor, checkout places like Ebay or gumtree and sometimes you can get an empty bottle from the recycling places where people take their rubbish.
🙂 Bob.
Mayflower
Mar 12, 2016
52
19
Jersey JE37YN
Profile
Hi,
Thanks for the tips.
I do have a U.K. calor gas bottle, but the fitting is not like the one in your post, yours doesn’t have a regulator on the pigtail, mine does ( see my earlier post ).
I want to obtain a pigtail,cut the one end off and clamp the barbed regulator to the other end.
I think that that will result in TWO regulators on the same line though !
MisterB
5,962
13,326
Adria 670 SLT
Could you set up a two cylinder configuration via a T piece, just having one cylinder open at a time? That way you only use one regulator a any one time?
SandraL
1,373
985
Somerset
Hymer b694sl
I,m confused. Two regulators in series is bad news.
Normal practice would be for your existing bulkhead truma regulator to be connected to your calor cylinder by a pigtail. If you are using patio calor gas cylinder you will need a clip on adapter, not a regulator.
Perhaps post picture of top of cylinder you want to use.
Sep 10, 2012
2,139
3,799
worcester
Sunliving van
Calor have 2 types of bottle. 1 with on bottle regulator other designed to connect to a bulkhead regulator.
If you must keep the on bottle regulator type then u need to tee into the gas pipework after the bulkhead regulator add a tap and a barbed connection. Then a simple low pressure hose connected with clips at either end.
(Bit like adding a barbecue connection but in your case in the gas locker if that's where the bottle will be.)
Mayflower
Mar 12, 2016
52
19
Jersey JE37YN
Profile
Thanks, I will.
bobandjanie
8,175
15,851
Javea, Spain
Pilote V600g
The gas bottle and regulator you have is for things like patio heaters and bbq's, the only way you could use that, is fed back through a bbq point and stand the bottle outside, and turn off your existing supply. 🙂
Your Spanish bottle has a valve on it, that why the pig tail ( hose ) has nuts fitted it's high pressure, if you used that bottle for a bbq, you would need a regulator similar to the one your trying to use, that would have push on pipe and jubilee clips on each end because its regulated so low pressure. 🤔
My advise is get the proper propane gas bottle and pigtail, 😉 maybe try and swap your bottle. 😁 Bob.
Mayflower
Mar 12, 2016
52
19
Jersey JE37YN
Profile
So you’re quite right.
it’s Calor gas patio.
so what I need is a pigtail to connect to my installed regulator and not the current regulator that fits directly on the bottle, if such a thing exists!
bobandjanie
8,175
15,851
Javea, Spain
Pilote V600g
Hi, just done a search and found this :
Your hose should screw straight onto it, it's an adaptor like your Spanish one, presuming your patio bottle is 21mm 🙂 message the seller and tell him what you plan to do, and ask him if it's what you need. 😁 Bob.
17,649
43,471
calor do more than the basic 2 cylinder types these days
RED Propane .. Pol
BLUE Butane .. screw on
GREEN patio .. clip on
Mayflower
Mar 12, 2016
52
19
Jersey JE37YN
Profile
Thanks for going to all the trouble, it’s appreciated. However it’s not 21mm, it’s about 27mm as TheBig1 says.
Mayflower
Mar 12, 2016
52
19
Jersey JE37YN
Profile
43,390
49,820
Have another look at post #7.
The bullet end of the hose screws directly in the propane bottle... Its a POL connector, left handed thread.
The other end connects directly to you onboard regulator.
Job done, no need to cut or bodge anything and only one regulator.
Incidently, what colour is your calor bottle.
17,649
43,471
But they have a patio gas cylinder John, not a standard Propane. The bottle is green
