Thanks, I will.I,m confused. Two regulators in series is bad news.
Normal practice would be for your existing bulkhead truma regulator to be connected to your calor cylinder by a pigtail. If you are using patio calor gas cylinder you will need a clip on adapter, not a regulator.
Perhaps post picture of top of cylinder you want to use.
Thanks for going to all the trouble, it’s appreciated. However it’s not 21mm, it’s about 27mm as TheBig1 says.Hi, just done a search and found this :
Caravan / Motorhome - LPG Butane Gas Hose Adapter – 21mm Clip On - SRG–Type 640 | eBay
LPG Butane Gas Hose Adapter – 21mm Clip On – SRG Type 640. LPG Butane Gas Hose Adapter – 21mm Clip On – Type 640.www.ebay.co.uk
Your hose should screw straight onto it, it's an adaptor like your Spanish one, presuming your patio bottle is 21mm message the seller and tell him what you plan to do, and ask him if it's what you need. Bob.
Thank you, I think you’ve cracked it.27mm Patio Gas Adapter for Butane Pigtail on a Caravan or Motorhome Regulator 58 | eBay
27mm Patio Gas Adapter.www.ebay.co.uk
I hope not, it might leakThank you, I think you’ve cracked it.
Explains it all.... You have a blue butane bottleThank you, I think you’ve cracked it.
But they have a patio gas cylinder John, not a standard Propane. The bottle is greenHave another look at post #7.
The bullet end of the hose screws directly in the propane bottle... Its a POL connector, left handed thread.
The other end connects directly to you onboard regulator.
Job done, no need to cut or bodge anything and only one regulator.
Incidently, what colour is your calor bottle.
Butane reg is a push/clip oncalor do more than the basic 2 cylinder types these days
Propane .. Pol
Butane .. screw on
patio .. clip on
