- Jan 11, 2018
- 1,276
- 1,619
- Chausson Welcome 85
- Since 2018
Quick question.
Are gas bottles part of payload?
Thinking of upgrading mine from 2x6kg to 11kg.
Tia.
Yes, everything has to be accounted for in the GVW.Quick question.
Tia.
ThanksYes, everything has to be accounted for in the GVW.
If you want to upgrade to 11Kg cylinders look into Alugas, which being aluminium are about the same weight as 6Kg steel cylinders.
Tia.
Back to School via Specsavers MrsDon't forget that as well as the different weight of 6kg to 11kg bottles you'll be putting more ??? gas in as well so that will reduce the payload.
Back to School via Specsavers Mrs![]()
Blimey, 6 x 6kg would affect your payload...@matamoros ...just subtract 6 x 6Kg and add 1 x 11Kg. Just keep below your max gross weight
Blimey, 6 x 6kg would affect your payload....
All manufacturers should be following the EU definition of MIRO which I believe is broadly:Are you asking about MIRO (mass in running order)?
Manufacturers want to present as low a weight as possible for MIRO and all seem to use a different definition. I think they all include one gas bottle, but it's usually an Aluminium one to keep it as light as possible.
MIRO includes a lonely 75kg driver (no passenger) some fuel and a few drops of water. Some include a (short?) EHU cable.
I thought liquid propane was about half the weight of water.Remember 6 kg bottles hold about 12lts gas =12kg
1KG LPG = 1.96 Litres.You May be correct but I have always based a litre of liquid approx 1kg to be on safe side![]()
Yes as I said I was not certain but I have twin 11kg refillable bottles and get around 22ltrs per cylinder never have weighed them but always have allowed my theory when loading van to be on safe side.Surprisingly a 6Kg bottle of gas holds 6kg of gas, which is around 12 litres
If you are 'filling' a 6kg bottle with 6 litres then it is only half full![]()
That will be the bottle weight plus the liquid weight.Yes as I said I was not certain but I have twin 11kg refillable bottles and get around 22ltrs per cylinder never have weighed them but always have allowed my theory when loading van to be on safe side.
A 6kg cylinder full weighs approx 15-17 kg according to calor.![]()
Don't forget that as well as the different weight of 6kg to 11kg bottles you'll be putting more gas in as well so that will reduce the payload.
I assume that the OP is changing 2 x 6kg for 2 x 11kg, otherwise why go to all the expense to have LESS gas?
@Jake Royd please clarify!![]()
Yes , I mean 2x6kg existing planning 2x11kg.
I was right ....
That’s what I saidThat will be the bottle weight plus the liquid weight.
https://www.motorhomefun.co.uk/forum/threads/lpg-litre-to-kg-conversion.146329/.
