Fitting Anwing pole holders (2 Viewers)
lorger
9,666
90,548
Dumfries
Knaus Sun 650MEG
We have a windout awning and always peg the legs down but we have a couple of holders/brackets that go on outside wall to hold the legs in. What i would like to know is how do i fit them do i have to drill them or can i just use a good adhesive to fit brackets.
Gerry
Oct 15, 2007
1,622
280
Five Roads Alyth
A class RV
since 2005
You'll need to screw (or bolt) them to a solid point on the body work. There can be quite alot of forces applied to these, wind, rain, banging your head on them so it needs a firm mount. If the disired fix point shows any flex keep looking for truly solid, and put a little sealant under as you fix so as to prevent any water ingress.
DESCO
2,646
266
London
low profile
18 years +12 years tugging
Agree totally have seen the side of a van ripped when only fixed to bodywork alone with nothing solid to screw into, this was after only one gust of strong wind.
Dave :thumb::thumb:
lorger
lorger
9,666
90,548
Dumfries
Knaus Sun 650MEG
Cheers guys for the quick reply i will have a look later and see if i feel like doing it myself im sure it should be easy enough if i find a solid part.
Gerry
43,337
49,538
hi Gerry,
dont rely on screws and glue.....the surface area is just too small for the loads imposed, unless you can locate any timber bearers.
you need to drill right through and place a spreader plate over the bolts on the inside.
a very easy job but some very careful measuring is needed.....and a couple of corresponding low level lockers/cupboards so the fixings dont show.
the back one should be ok due to the rear lockers but the front bracket may end up behind the fridge or cooker.:Sad:
DMS
Trader
205
161
Concorde 850L
Time Began
If its for the fiamma awning then you can get a fixing kit from johns cross motorhomes at around £12 inc postage.
As for the fitting the fiamma kit. this requires 2 x 10mm holes drilled through the side of the van and comes with a bracket for you to fit on the inside then screws in from the external side using 2 x screws (supplied) also just before fitting a drop of silicone or sikaflex aroung the holes would be required to protect it from water ingress. This is required for each bracket. Sounds Daunting but its rather easy. (just get the height right first) also check internally that there are no obstructions before drilling.
regards
Alan
Direct Motorhome Services
Oct 29, 2008
5,073
5,974
West Yorkshire
Personally, I would not fit them, especially on a large awning. When a strong gust of wind gets under the awning it acts like a sail putting all the strain on the fixing points and the panels.
lorger
lorger
9,666
90,548
Dumfries
Knaus Sun 650MEG
Thanks for all the replys i think i will leave it till i come home from hols as away on monday and dont want to have big holes in side of van. We only want to use them as sometimes when we stop cant get pegs in ground or just stopping somewhere for an hour.
Everyone says its an easy job but sounding harder with each posting:ROFLMAO::ROFLMAO: think i will just use double sideed tape:ROFLMAO::ROFLMAO:.
As for hiding screws from inside we have a long sofa at that side so should be under that and a small cupboard at back so that should be ok.
Thanks Guys
Gerry
Geo
Trader - Funster
Jul 29, 2007
11,757
14,565
Mansfield,Notts
Autotrail Tracker FB
45 +years with breaks
Thanks Guys
Gerry
Over complicated instructions thats all
4 x 6" nails bent over inside van, sorted:thumb:
Geo
lorger
lorger
9,666
90,548
Dumfries
Knaus Sun 650MEG
heers Geo i knew paying my £12 on here would save me loads of money when doing jobs on van should i use galvanised nails or will that not matter:ROFLMAO::ROFLMAO:
I could also use the nail for hanging stuff in the inside:ROFLMAO::ROFLMAO:
DMS
Trader
205
161
Concorde 850L
Time Began
lol knowing geo they would be the rustiest nails he could find.
Like his fishing hooks :ROFLMAO::ROFLMAO::ROFLMAO: :thumb:
Geo
Trader - Funster
Jul 29, 2007
11,757
14,565
Mansfield,Notts
My rusty nails are my fishing hooks
Oh my gawd just had flashbacks of that sharrrrrrk I caught:Doh:
