- Dec 11, 2011
- 839
- 2,102
- AutoTrail Tracker RL
- since 2010
Have you tried both fans individually - I wonder if one of the fans is duff?
Have you by any chance wired the fans the wrong way round and they are loading the 12v supply, sounds like when the relay pulls in the volts drop and it resets.Fitted the fan and W1209 controller today. Not a good result. Wired the input currant to the ground and live, checked for voltage and all was fine, 12v plus. Then looped from the live into K1, rechecked, all still good. For test purposes, I set the temperature to 20 degrees, warmed the probe up to 22 degrees, the controller switched on, I checked K0 for output and again, all was good. I then wired the fans to the controller, live to K0 and negative to ground, waited to 22 degrees for the circuit to open. At 22 degrees the circuit opened but all that happened was the controller just kept clicking. I checked both the out going voltage and in coming voltage and both read 10.5volts. I'm confused, where did I go wrong.
Not sure I follow you. Can you post a picture of your wiring?
I have just fitted a CBE vent fans and controller.@Baycott / @Gellyneck - this is the one I was looking at http://www.rainbow-conversions.co.uk/fridge-vents/vento-12v-electronic-fridge-fan-126-p.html
but I'm sure someone posted that they'd found it for under £30 - but now I can't find that post!
Just found it - it was Amazon (possibly the link you provided) and the price was £29.71 incl delivery (post was on a FB group). Looks like they've increased the price or the original seller has sold out.
What you've wired it to can't supply the current to run the fan. If the ground connection is good, find another positive to wire to.Fitted the fan and W1209 controller today. Not a good result. Wired the input currant to the ground and live, checked for voltage and all was fine, 12v plus. Then looped from the live into K1, rechecked, all still good. For test purposes, I set the temperature to 20 degrees, warmed the probe up to 22 degrees, the controller switched on, I checked K0 for output and again, all was good. I then wired the fans to the controller, live to K0 and negative to ground, waited to 22 degrees for the circuit to open. At 22 degrees the circuit opened but all that happened was the controller just kept clicking. I checked both the out going voltage and in coming voltage and both read 10.5volts. I'm confused, where did I go wrong.
I fitted one of these last month and I know you could probably get the bits and make one for less money but why have the hassle. There is a nice small control unit that allows you to run it on manual, which means the fans run at full speed or you can run it on auto and control the temperature, which means the fan speed is determined by the temperature behind the fridge.I have just fitted a CBE vent fans and controller.
fitting-cbe-fridge-fans.156720
Does what it should and quality looking kit.
Martin
Takes all the fun out of the job, why would you want to do that.Job done, no trawling the eBay for a fan here, a thermostat there, and a control unit and then wondering where all the wires fit if you are not into electrical items like me.
Just got to say the fridge does get cooler.
Cos I have better things to do.Takes all the fun out of the job, why would you want to do that.
Dont Buy Brunner Vento system I have had TWO gone belly up in a matter of weeks now just put a THIRD one in,, see my other posts
Thanks for the reply, but I meant the positioning of the sensor itself.. should it be as high as possible at the rear of he fridge?My understanding is that these fridges lose efficiency when outside temp is over about 30 deg C so I assume that the temp controller needs to be set to about this temp
