scotjimland
- Jul 25, 2007
- 2,334
- 10,102
- A Woosh bang
deleted
@Tykat
Don't know the Gas Safety regulations or guidance for using Faro poly pipe in a caravan, so can't comment ..
... that's pretty much what the engineer's report said but in addition the pipe itself appeared to have been cut short when they fitted the t-piece for the BBQ pipe and this put the connection itself under stress ... this is why I suggested a putting on a bracket to ensure the pipe can't move - if ours had had this on it wouldn't have been able to come out of the joint no matter how bad the connection was.If your pipe came out of a fitting it wasn't done by a competent gas fitter.. or if it was he was extremely careless , and coming out had nothing to do with how well it was fixed to the wall.. obviously the olive wasn't fitted properly and correctly torqued up..
Yup ... we held firm and made them get an independent engineer report done before they got their grubby little mitts on it and then they had to follow his re-installation instructions to the letter ... we did get all the work repaired and the use of 2 motorhomes for our booked holidays whilst this was all going on before they fixed it, and then they forgot about replacing the slightly scorched kitchen worktop so we agreed to live with it (fortunately it was only visible underneath) and got a free hab check and service out of them as compensation.sounds to me like it was a bodge job from start to finish .. I hope you had serious words with the dealer !
My concern is if others copy the installation, which they may, then their simply fitting a small bracket to the pipe itself would ensure it could not come out regardless of how well it has been done ... belt and braces like!so no worries , my pipework is adequately secured,
but thanks for your concern..
I don't think I've got any 'after' photos but I can assure you it was way over engineered to make sure it could never happen again ...regarding your near miss.. what a bodge of a job ..
I don't see ANY support brackets in the pipes, do you have a picture of the job after it was redone ?
As said the issue would be with insurance . If you had a problem and it causes damage the first thing an insurance company will ask is who fitted the gas point .
I have spoke to insurance companies on carrying out DIY modifications to gas and electric and the reply I got is it has to be covered by a certificate .
Are the bracket spacings in relation to a static (ie domestic) installation rather than in a moving vehicle? Just curious.
Generally I agree with what you say. I carry out my own DIY work on my motorhome if I think it is within my capabilities. That includes most electrics and gas.
But just a note of caution. "Beyond reasonable doubt" as a concept is only used in criminal law cases. This would be a civil law case, in which case the burden of proof is based on "the balance of probabilities", i.e. what is more likely than not to have happened.
