- May 14, 2018
- 331
- 430
- Autograph 794-T
- Caravan owner moved on to Motorhome
Am I the only one here that gets very very very bored at the speed that the grey waste tank empties? Has anyone done a 'pumped' conversion on theirs?
Yeah... even that is very very boring to watchIt’s best to run a pipe from the drain to the edge of your pitch and leave it open
Whale | Global Supplier of Pumps, Heating Systems and Plumbing
Whale is a global supplier of high quality low voltage pump, plumbing and heating systems designed for mobile applications and challenging environmentswww.whalepumps.com
Perhaps??
That is entirely helpful.. thanks.It’s entirely possible that you may need to get out more
Its so slow. It can take 10 minutes to empty the tank as the bore is so small. Plus of course the drain cock is so near to the ground that it can get ripped off the van going over speed hump etc. Not exactly an elegant solution from BaileyGravity should do the job, has it always been a problem .
Seems a little overkill to carry a WasteMaster when you already have an onboard waste tank, but I take your point, it would certainly avoid holding up a queue of other MHs all waiting at the service point to dump their tanks.I use a low level wheeled tank and run pipe in to it and leave valve open when pitched so when ready to leave tank will be empty , just wheel tote tank to tip out.
When I had a caravan and a Disco 4 tow car, I did once loop the WasteMaster handle over the tow hitch and tug it to the dump point.. now that's lazyBet no one visits you. It stinks.
I have a low level tank on wheels but not as low as the drain pipe. When I tip the tank over 45 degrees to remove it from under the drain half of the stuff spills out. Means it’s not so heavy to tug to the service area
Perhaps I'll shove a brush up it.. but its been rubbish since new.Might need a colonoscopy (spelling ) I would try a drain cleaner before going mechanical
Its the same diameter as convoluted pipe (28.5mm)Paul....How big is the bore of the waste pipe? I thought the Bailey was easily 50 mm?
Kev
Thats surprised me? Thought it was bigger than that? Our neighbour has the same vehicle and he has a 50 mm outlet. What I dont know is if he has altered his because of the same reason you now have?Its the same diameter as convoluted pipe (28.5mm)
You don't want to get straw up it, it's very scratchy is straw, Very scratchy.Mine was ridiculously slow once, (even more than normal). It transpired that there was straw up it where a little mouse from the storage farm was thinking about making a nest.
Buy a better motorhome!!Am I the only one here that gets very very very bored at the speed that the grey waste tank empties? Has anyone done a 'pumped' conversion on theirs?
