Electrical help please (1 Viewer)
andynkim
107
200
Mobilvetta K-Yacht 85
Had you brought it in from the cold? seems like something (damp and dirt) caused the tracks to arc and burn then the fuse blew. I would clean the area, change the fuse then clean the track around the damage and apply some solid wire to beef it up. then stand well back and try again.
Mar 15, 2019
518
933
AutoCruise Stardream
Newbie April 2019
Was just typing pretty much the same thing. Clean it and change the fuse. If you've got an rcd plug as well even better.
Jan 19, 2014
9,395
24,791
Derbyshire
Elddis Accordo 105
since 2014
Probably the transformer gone short then. Unsolder it and check the primary resistance and resistance to ground.
If I was working on an AC at work we'd just order a new board if there was any problem with it. There will be a serial No. On it ?
Jan 19, 2014
9,395
24,791
Derbyshire
Elddis Accordo 105
since 2014
If it's not an inverter type the first thing I would do is put a 230v feed straight to the compressor to see if it starts and runs OK. It's all a waste of time trying to repair/replace the board if what's caused it is a seized up compressor ?
Oct 29, 2008
5,072
5,973
West Yorkshire
It looks to me that the area has been damp for a long time causing mold or fuzz to build up on the pcb.
Without having the board in my hands I cant see exactly where the burn is between but it looks like its the rear of the mains input. Is that correct?
If it is its just flashed across between either L and E or N and E. If that is the fact, clean the PCB up with a fibreglass pencil and put a new fuse in and hopefuly you will be OK unless the flash has knackered other components.
Oct 29, 2008
5,072
5,973
West Yorkshire
To add to that, from the photo there looks to be other fuzz on the board around 2 pins on what I guess is the underside of the transformer and other areas, so give it a good brush up before reconnecting
Fuzzy areas highlighted in red that need cleaning. Blue highlighted area has possibly been slightly corroded by damp on surface.
Figaro
Feb 22, 2011
9,800
20,204
Newcastle under Lyme
Hymer B544 A Class
Yes the damage is between the live and neutral next to the input. Main fuse in between.
I'll try running the compressor direct and make sure it's working.
Would a bit of solder on those lines after cleaning do the trick ?
There was a fair bit of dust on the PCB I cleaned some up before photo but I'll do a proper clean up before going any further.
Oct 29, 2008
5,072
5,973
West Yorkshire
Dont solder it, it needs cleaning. Don't test the compressor unless you have checked the circuit diagram and you know what you are doing. Besides theres no need, put a fuse in after cleaning all the print making sure no carbon is left between the two areas where the 240v has jumped and brush any other fuzz or corrosion off.
Then put new fuse in and test. If it blows again I would remove the mains smoothing capacitor and test once again with new fuse.
After that you will know the board is either good or knackered.
Oct 29, 2008
5,072
5,973
West Yorkshire
BTW you may need to clean the flashed area out quite deep to remove all the carbonized area, but the tracks ant both sides of the area are wide so dont need repair
Figaro
Feb 22, 2011
9,800
20,204
Hymer B544 A Class
Ok, what should I clean the tracking with, you mentioned a fibreglass pencil ?
Not got one but maybe eBay can assist.
Can the rest be just brushed / vacumed off.
Would PTFE spray help clean ?
Jan 19, 2014
9,395
24,791
Derbyshire
Elddis Accordo 105
since 2014
I've never seen moisture conduct 10 amps blow copper tracks off a pcb. For that to happen there is a low resistance short. Still there's no harm cleaning it up.
The smoothing capacitors smooth the rectified DC on the other side of the transformer, doubt it's anything to do with them.. IMO ?
Jan 19, 2014
9,395
24,791
Derbyshire
Elddis Accordo 105
since 2014
It does look like something was between the L and N on the pcb tracks looking at the pic again mind ? just test the L to N resistance before powering up.
RandallC
1,242
3,487
Devizes
A Class Rapido 8096
2012, prior too, 17 years Folding Camper & Caravan
Had a similar problem:
Probably caused by damp and a flash over on the pcb.
you will need to scrape out the carbonised PCB section between the two copper (green lacquered) tracks to remove the short.
Can be filled with insulating lacquer/aradlidite.
Any damaged tracks need to be repaired, scrap off the green lacquer and solder copper wire across any breaks or thinned sections.
Ensure pcb is dry and warm and spray with insulating PCB lacquer. (have used the equivalent of wd40 in the past to get the thing away)
Replace the fuses and retire to a safe distance and test.
Good luck.
May 29, 2013
2,603
19,279
Tyneside
Chausson best of Flash 10
Several years now
If it was a short-circuit of some part of the circuit, then assuming the fuse did not blow quick enough then you'd expect to see one of the pcb tracks melted / broken, maybe the fuse would then have blown or not.
This does not seem to be the case, rather it looks like a short between the live and neutral tracks which would cause the fuse to blow faster as the current was destroying both tracks.
If it were me I'd clean right round the damaged track area then repair each track by soldering a bit of meaty wire over the damaged section, (making sure to remove the protective coating for about 1cm on the good bit of track you are soldering to), effectively bridging the gap, flood the joint with solder and test again.
Oct 29, 2008
5,072
5,973
West Yorkshire
Mains smoothing is across the mains near the input not on the DC side It protects the board from spikes.
Going by the clues that are there of fuzz and watermarks on the board Im going with my diagnosis. There are no tracks blown off the circuit board! It has arched between tracks! Its all there to be seen!
Oct 29, 2008
5,072
5,973
West Yorkshire
Clean the board, dont put any lubricant on. These are ideal for all sorts of cleaning Scratch brushes and PCB Cleaner spray you could use a pure alcohol like isopropyl but either way make sure its dried before turning on. Use a hair dryer if in a rush
Jan 19, 2014
9,395
24,791
Derbyshire
Elddis Accordo 105
since 2014
I think you're you meaning that inductor/choke top left? I've never seen an AC capacitor just put across the mains, it would just waste power charging and discharging with the sine wave.
Smoothing capacitors are for DC. Don't take my word for it though, Google it ?
Oct 29, 2008
5,072
5,973
West Yorkshire
There are a lot of people suggesting all sorts but the facts in plain view for those who understand enough to look at the PCB are.
A. Its arched between tracks. Not blown a component any thing else
B. There are signs of contamination on the PCB which could have been condensation or water ingress (no way to know unless there are further clues in the unit)
C. The fuse has blown
Other than that the rest is guessing.
Without the circuit diagram or having technical knowledge its no use suggesting further testing as you would be just guessing.
11,956
16,570
There were two pops when I plugged in ... .... eek :eek:
What might cause an overload ?
To be fair I did use a bit of cable laying around and not 2.5mm but it looks ok.
That damage is between the live and neutral with the fuse in between, and both go to the copper coil.
Thanks for help tonyidle , does it look repairable or toast ?
I'll email apuljack tomorrow.
Cable size wouldn't affect the unit. The copper coil (toroid) has two windings: one passes the live straight through; the other passes the neutral straight through. Neither winding should be in contact with the other. It is a simple suppression device.
I've just taken a detailed look at it. I believe the fault was something shorting the tracks either side of the damage which has now gone. The tracks, despite appearances, will be OK. Replace fuse and try it again. You may wish to clean the damaged area with a little thinners / alcohol / nail varnish remover then cover the patch with clear nail varnish. The PCB function is definitely unaffected by what has happened and I'll be very surprised if there's any collateral damage.
As suggested by others if I'd read right to the end :blusher: .
Figaro
Feb 22, 2011
9,800
20,204
Hymer B544 A Class
That's very encouraging, thanks.
I'll order some fuses, clean up a little and report back in a few days (y)
Thanks again to all who helped
Jan 29, 2017
685
558
Gloucestershire
Lunar Champ H621
15yrs
You mentioned ptfe spray, dont get that anywhere near where you want to solder, its a non stick spray!.
A bit unusual for a track to blow off like that, it would have been caused by excess current perhaps due to poor insulation ie damp between the tracks at that point
Keep your fingers crossed.
I still think it may be a seized compressor or lack of gas, did you follow the compressor resting instructions before switching on? Itll have a good rest, the right way up etc whislt you think about it.
Mike
Figaro
Feb 22, 2011
9,800
20,204
Hymer B544 A Class
I`ve not used any PTFE on it.
Since last post I just got a soft brush and vacume to remove a build up of dust on the pcb.
I`ve ordered some of those clean up pencils and replacement fuses. When they arrive I`ll clean up the damage and coat with clear lacquer as suggested, fit fuse, reconnect and hope for the best :LOL:
There was no damp apparent, it stood overnight in the garage but not particularly cold.
It was tested and working apparently last month by a motorhome dealer who fitted a new unit for the seller.
I`ve not read any resting instructions in the manual but to be honest it had not been tipped up or overturned in the hours before I tried it.
As you say, fingers crossed
May 29, 2013
2,603
19,279
Tyneside
Several years now
The photo does show some pcb track missing, for peace of mind I'd build up the remaining track using wire and solder. Reduced track could result in overheating in that track area and therefore further problems. It would do no harm after all.
Figaro
Feb 22, 2011
9,800
20,204
Hymer B544 A Class
Fair comment, if all works ok when I clean it up and plug in, I`ll remove it again and see if I can get the track repaired locally as you suggest.
