- Feb 22, 2011
- 10,850
- 22,872
- Hymer B544 A Class
- Since 2015
I bought a used dometic air con unit (B2200) off a funster and decided to bench test it before doing anything.
The electrical connections are simple enough, block connector to face plate in hab area and live neutral and earth which I fitted a 13 amp plug to. Plugged into extension lead ....... pop. !!!!! Bugger.
A fuse on the PCB has blown and I hope it protected it sufficiently to prevent damage.
For the life of me I can't see where I've gone wrong, all connections good.
Am I missing anything obvious ?
Any ideas where to go from here ?
I don't think I have a correct fuse to replace the blown one so can't do anything today.
The unit was tested, found working and removed by sellers dealer and sold in good faith so I've no problem with seller.
If junk and not repairable, I'll just put it down to experience, but seems a stranger one.
The problem I'd expected, if any, was going to be fan working but no cooling.
Any help / suggestions please ?
