- Sep 9, 2013
- 620
- 3,106
- Hymer S840
- First moho 11/2013, second 11/2014 current from 09/2019.
Some advice please, here is the background...
Hymer with a EBL101 electrobloc and a DT201 display. 100w solar panel. Votronic mppt 250 with connection to the EBL. Efoy 1200. 1200w pure sine inverter.
I'm sure our two year old Hancock lead acid batteries are knackered (110ah x 2) as according to the DT201 display they do not charge to 100% having been on hook up for 16 hours. A couple of nights ago the system shut down as the voltage had dropped so much (we were using an electric fan through the inverter). Even the efoy won't charge the batteries, the display shows 'check battery' which I believe means the battery voltage is so low it won't start!
We are in Greece at the moment with about two weeks until we get home, hopefully we can get by for this length of time. We've been away for 10 weeks and have been on hook up twice for 24 hours so I think we have done pretty well as we are confirmed FLT!
Our future travel plans are to be away for two or three months at a time in Europe.
When I replace the batteries would you suggest 2 x 100ah lead acid, 2 x 100ah gell or 1x 100ah lithium? If I go for the lithium I'm pretty sure I will need a supplemental Schaudt charger as the EBL puts out 14.4v at best.
A further thought is to add more solar.
My ideal outcome is never to have to look at the DT201 battery display having full confidence that all is well.
All suggestions will be appreciated.
