Elddis Encore 255. Control panel (2 Viewers)
Dec 30, 2015
1,428
1,272
Bury
Pilote G650L
Three years
Any idea of the make and model of the control panel? Or is it specific to Eldiss?
AndyPK
5,012
13,896
Cirencester
None……..!
Motorhoming since 2015......
…or a photo of the screen perhaps?
(I have an Elddis 155, so may have the same/similar screen….. :unsure: )
B
Big Vern
Exeter, UK
ELDISS 255 ENCORE
The panel is made by BCA electronics. Distributed by Penine leisure (same group). Fitted by Elddis .It is a new control panel fitted under a used vehicle warranty (2017 model Encore 255) from a dealer. When first fitted in july the mains icon was displayed permanantly,hooked up or not!.Back to the dealer!. Now it its not displayed at all when hooked up! Its taken a while to come to my attention because i very rarely hook up to mains.( i use solar panels via 2 x105ah lithium leisure batteries). The dealer is giving me all sorts of excuses,i dont think they know what their doing. A bit long winded but all advice and help is much appreciated. Big Vern.
Dec 30, 2015
1,428
1,272
Bury
Pilote G650L
Three years
Sounds about right. :oops: I think practically every panel ever made shows the icon when hooked up but nothing when not hooked up.
AndyPK
5,012
13,896
Cirencester
None……..!
Sorry….different panel to the one in our ‘van:(I only know when we’re hooked-up to the mains because the microwave clock is showing……. ;) (and the cable trailing from the back to the nearest bollard, of course!)
Feb 9, 2008
8,951
18,707
Corby, Northants
Coach Built
I know this is a shot in the dark and perhaps of no value to you what so ever, but is there a manual covering the control panel
Eggs
1,633
2,934
Suffolk
Welcome.
Do you know the model number of the BCA control panel? As said above, a picture would help.
Feb 9, 2008
8,951
18,707
Corby, Northants
Coach Built
Found these after a quick search. They may help you , they may not.
Apr 11, 2015
5,414
55,180
hull
Laika Ecovip 300
Wehad no hook up showing on on our panel for over a year, investigation showed that the charger had been accidentally switched off 😬
AMK
283
202
gainsborough
Coachbuild
Since 2014
it will show on your Alde display not your control panel, your control panel is just for the 12 volt.
that’s how my 2016 Encore works.
PEM
Jun 5, 2011
66
110
Lancashire
coach built
Hope this helps just taken from my 255 clearly showing ehu on plug and cable right hand logo on panel
B
Big Vern
Exeter, UK
ELDISS 255 ENCORE
MASSIVE THANKYOU FOR THE PHOTO AND YOUR TIME. YOU HAVE PROVED MY POINT. IN GENERAL I AM VERY HAPPY WITH MY ELDDIS 255. WILL KEEP IN TOUCH TO SWAP KNOWLEDGE. BIG VERN.
Dec 5, 2017
495
11,346
York, UK
Bailey Autograph 745
Almost approaching average
This happened to us recently. No hook up symbol but all 240v stuff worked fine. Solar was charging batterie but the charger wasn’t. In fact it seemed like the opposite was happening somehow. Fitted new charger and all back to normal again.
Feb 9, 2008
8,951
18,707
Corby, Northants
Coach Built
Hi, Thanks for your reply. Are you aware your typing with your Caps Lock on which means everything is in upper case and regarded by most people as a form of shouting ! A simple mistake that I fell foul of a few years ago hence my knowledge of the subject LOL. Hope you get your query resolved. You will get lots of support on here if you have a problem. Some advice good and some useless. By the way you have posted a reply on my profile page rather than this tread ! No harm done though and in fairness it does take a little while getting used to how this forum works. Keep Safe,
AMK
283
202
gainsborough
Coachbuild
Since 2014
I checked mine this morning and it doesn’t show the 240 only the water level symbol.
I best check the charger fuse.
