Ducato Door lock vulnerability (2 Viewers)
Jan 27, 2018
2,674
2,125
Northampton
Rapido & Bongone
The old screwdriver up the xxx, as prevented by proplates. are post 2016 models still susceptible to this attack or is the internal modification up to the task. HAs anyone with a post 2016 model been broken into this way?
Mar 11, 2014
934
1,331
Lincs
I think that Steve and Soz is a 2017 (but not sure what the base vehicle is) and theirs was recently broken into this way as they described here.
Feb 27, 2011
14,737
75,976
I work under the assumption that ALL manufacturers are crap and a top priority for me is to fit new deadlocks.
The problem with manufacturers locks are that there are so many of them out there that eventually an exploit will be found. With deadlocks this just isn't possible without a decent skill level in lock picking.
Oct 29, 2016
4,504
52,744
Surrey
Carthago C Tourer
Hi Gromett
Are we talking about fitting Hoesafe deadlocks fitted inside the cab doors, or something lockable from outside?
I would love to see any DIY options for exterior deadlocks on cab doors as they are at least visible to anyone trying to gain entry.
Thanks.
LES
Feb 27, 2011
14,737
75,976
Hi Gromett
Thanks.
LES
I am talking about fitted to the vehicles doors not the habitation doors on coach built vans.
A thief trying to take a coach built C class will want to be able to enter and exit the van doors. A rapid escape is not possible if they enter through the hab door and get pulled over. Thieves are cowards generally speaking.
A class van's are a different matter altogether I think.
I have been on PVC's for quite a while now and fitted deadlocks on all doors.
The heosafe internal ones are better than nothing but I don't think they are much of a deterrent unfortunately.
These are the ones I am fitting to my current van.
Pugsy
516
1,376
D&G
Van conversion
Plenty vids on youtube that show a complete lnstalation,have a search.
Cheers Cris.
the1andonly
Jan 27, 2018
2,674
2,125
Northampton
Rapido & Bongone
Yes deadlocks may be effective but has the original lock been upgraded and less susceptible to this type of attack?
43,329
49,444
My last Kontiki had electronic dead bolts.... Basically solinoids.
Fitted through a hole in the door frame with a corresponding hole in the door end with strengthener plates.
25mm diameter Bolt held back under 12v power so even if power removed it remained locked.
The only way past that would be cut a hole in the door skin and push the bolt back with a finger etc. IF you knew where the bolt was.
the1andonly
Jan 27, 2018
2,674
2,125
Northampton
Rapido & Bongone
Back to original question does fiats mod actually prevent access
Ps not interested in how marvelous deadlocks are
Deneb
1,598
2,334
Europe
No. It may prevent or make the screwdriver slipped behind the handle moulding trick more difficult, but thieves will adapt to techniques they use on other vehicles, which I won't describe here, but can still be done in seconds although with more damage apparent.
Kozikot
434
1,187
Benimar Mileo 282
Newbie ish...
Cheap Ducato Cab Door Locks...come with Jack nuts as well so very secure...
You don't have to cut the trim, but a bit of belts and braces on my part...
The Price you see is for a Pair...
Then just us the Hab Door to Exit, with a Heosafe 1958W locked fitted...
Not Foolproof but a Decent way to secure Cab Doors...
Monty don
371
408
Milton Keynes
a class
Since 2000
The easiest way is screew driver in lock barrel and turn. Easy peasy 2019 Ducato shite
Mine where done this year. Im going to blank them off with a metal plate. Don't need them with remote control and odds of the Remote not working very slim.
Monty don
371
408
Milton Keynes
a class
Since 2000
I have designed a small plate about the size of a 2 p piece and you glue it over the lock
That will stop anyone just coming along and putting a screw driver in the lock and twisting it and buggering it up
If you don't stop that you will always get your lock buggered even if they cant open the door much etc from other devises inside
Only option really to solve the screw driver lock attick
