Drip Requires Condensation Advice (2 Viewers)
Tootles
Sep 14, 2013
9,511
34,800
Lancaster
Was a newbie, now a Middie.
The only condensation I seem to be getting on cold mornings with the Hymer, is from the sloping front window over the luton. Seems a bit amateurish to just bung a towel there, and so has anyone developed a simple method to either stop the conden happening in the first place, or to catch said drips??
Ta. :thumb:
Vlad The Impaler
1,633
2,227
Rutland
Since 2012 but longer in my dreams
The secret to getting rid of condensation is better air circulation.
Blown air heating or a fan,even just a few windows open on the first clasp.
Vlad
Tootles
Tootles
Sep 14, 2013
9,511
34,800
Lancaster
Vlad
Done all that Vlad, and it works on all the other windows, However, it's just that one very high window, and I think only because it slopes, causing more of a problem.
Dec 6, 2011
11,598
25,452
South Wales
Coach built Adria
hot air rises so thats probably where its hitting the cold window. perhaps some form of extra insulation on that window. prob have to be on the outside like a mini silver screen:Doh:
Mousy
3,486
20,326
Sa15 2DG
Hymer S840 Merc auto
Employ a window licking nutter...there is one on here called paddy something :ROFLMAO:
themogs
880
915
Wales
Not Long Enough.
:Smile:Hi Tootles ::bigsmile:
We only started M/Homing 2 years ago, and had same problem:cry:
An experienced M/Homer told us to get an EXTERNAL silver screen (preferably the genuine article, with a pull down bit for the daytime:RollEyes:), and it works a treat. NO condensation for us in the mornings now...job done.
:thumb::thumb:
Tootles
Tootles
Sep 14, 2013
9,511
34,800
Lancaster
:thumb::thumb:
Thanks for that. How do you get to it, to fit the screen? I would need at least a nine foot ladder. Do you use the roof ladder, and walk across the top?
GJH
29,450
38,827
None, now sold
2006 to 2022
:thumb::thumb:
I think that's the answer to the main windscreen, not Dave's problem.
You would probably need to make (or have made) a bespoke external screen to fit the window. It could probably be fitted from the inside but would need something to keep it in place - maybe suckers like car windscreen frost covers or elastic fastened to both sides.
Dec 6, 2011
11,598
25,452
South Wales
Coach built Adria
i think theres cross wires here, moggs was talking about his windscreen i think.
however, you could try an experiment with extra thick or a few layers of bubble wrap and fit it from the inside ( open window, put insulation on outside of window , secure with some large elacy bands, close window, see what happens. or am i just being silly:Doh: it has been known :Eeek:
Tootles
Tootles
Sep 14, 2013
9,511
34,800
Lancaster
Its a really stupid window, Phill, only accessible from the inside by lying on the luton, and its a fixed panel window, dosent open, however, the bubble wrap has given me an idea, making a fixed inside panel I can secure over it. Thanks again.
jackrussel
54
45
south cheshire
Burstner Elegance i821
nada
condensation
Ta. :thumb:
You may like to do as I have done, buy a dehumidifier; true, only works on hookup or genny (240v), failing that, one of those crystal filled damp traps, which will use up crystals as a consumable. Could get expensive! Unless you only use them when its cold outside. Silver screen option good if you suss out how to get up to fit and remove it. Can you live with it left on all day- but obviously not on the move. My dehumiddy was bought from ebay, its a dessicant type, and gives warm air out to boot, so offers heat. Bit too warm for late summer cool evenings sometimes...but stays 100% dry inside, however cold out.
bernardfeay
613
1,191
Bolton
hymer exsis
10 years
I never thought I would be the one to solve this. You get a really good sponge and mop it up. In other words you just live with it.
I know, I know, I should be pitching on Dragon's Den.
themogs
880
915
Wales
Not Long Enough.
We put ours on by using the small step we carry around with us...no problem.:thumb:
But ours is a Ducato 130 and is easily done....but an Hymer ?? err.. not sure. :Sad:
schojac
339
234
Cambridgeshire
new in 2009
As a first option you may like to try some radistor insulation - the silver sandwiched bubble wrap stuff. Not too expensive and easy to shape; plastic suckers to secure. You could double up the thickness to make more effective.
I actually use this to make sucure all my windows when stored; keeps prying eyes away and also protects expensive main screens from the sun.
Tootles
Tootles
Sep 14, 2013
9,511
34,800
Lancaster
Thought about a dehumid, but it would have to be fairly small.......In fact, can you give me the make and model of yours??? I like the warm air option. :thumb:
jackrussel
54
45
south cheshire
nada
dehumidifiers?
Tootles,, its very similar, but not identical to, this:-
Mine was ÂŁ169 IIRC, and is dark grey metallic colour. It does indeed do the business. Sometimes, I think the air is too dry, but, if set at a lower setting,(60% RH) does not quite remove it all, 40% may do it- I will be trying that in the next 2 weeks- but I don't have it on during the day, so the air can be quite moisture laden by bedtime. The 'laundry' setting does what it says on the tin, just be aware of the water level in the tank (tho' they autostop when full). Not too noisy either; if you can tolerate a fan, this shouldn't cause a problem. I used it in the house also, and with just as much success. Good kit!
11,932
9,097
Only really got two choices ::bigsmile: board over it or insulate it ::bigsmile: if nothings done then it will keep condestating up causing damp problems --try putting a few layers of bubble wrap on it -I simply stuck some thermo/celotex board on ours -did not let light in but stopped condensation -simply took it off come sale time :winky:
terry
Nov 18, 2011
11,862
43,055
Planet Earth
A van
Over 25 year's
hats wat we used on our last van up in the lotion windows it worked a treat
