Dometic 3-way fridge/freezer ~2004, takes 15-20 clicks to get it going on gas - normal? (1 Viewer)
MH04RMV
84
186
Cheyenne 632 SE
Hi Everyone,
My Dometic fridge/freezer is taking anything from 15 - 20 cycles (i.e. turning from off to on and back to off) before it eventually fires up and the yellow light stays on.
Is this "normal", e.g. it's just taking a while for the gas to get through the pipe (even though hob burners fire up straight away)?
Or...is something on the way out?
The ignition clicks don't sound like they're running low/out of juice.
Is there a safe manual way to light the fridge up, so I don't have to waste 20 minutes praying to the gas gods for it to work?
Cheers,
Rich
Apr 2, 2020
38
86
Self conversion merc
Since 1998
Mine turned out to be the selector switch after I'd changed the thermocouple etc . Or ring dometic technical their pretty good
Feb 22, 2011
9,970
20,606
Newcastle under Lyme
Hymer B544 A Class
No it doesn't sound right.
When you switch to gas, does the yellow light flash, or is that why you have to repeatedly turn back to off,just to get the light flashing ?
The yellow light shouldn't stay on, it should go off when lit by pressing in and holding the temp selector button.
What model fridge is it ?
JockandRita
11,526
151,064
Lincs/Cambs border
N+B Flair 8000i
Since May 05 (Ex Tuggers).
Hi Everyone,
Cheers,
Rich
Ours is a Dometic 7 Series F/F. I find the manual changeover from 240v or 12v to gas is instant, with only a couple of clicks of the igniter at the most.
I did have a problem with the auto changeover, which turned out to be a problematic PCB, which I managed to hunt down and replace, however, parts for the 6 & 7 Series F/Fs are mostly now obsolete. :(
Good luck getting it sorted. (y)
Jock. :)
M
MH04RMV
84
186
Cheyenne 632 SE
Hi Figaro JockandRita
Apologies, I'd forgotten about this thread/query...
It's a manual rotating dial selection between 12v/240v/gas...when selecting gas/"switching on", the yellow light is flashing while the ignitor is firing, and after 15-20 clicks the ignitor stops, so I have to turn it "off" (e.g. back to 12v), then turn back to gas to repeat the ignitor firing sequence.
I'll try and take a video of what it's doing and attach here.
I can "kind of" tell when it's about to light successfully and the yellow light stay on, as the ignitor firings are a bit slower & sound "fatter".
Once it's lit, it seems to stay alight without any issues, and cools quite well...it's just such a PITA to get it lit!
I've no idea when it was last/if ever serviced, so maybe I should get that done first, to see if that picks up an issue with any part(s)...?
Cheers,
Rich.
JockandRita
11,526
151,064
Lincs/Cambs border
N+B Flair 8000i
I would consider taking the burner apart and cleaning the small jet etc.
And the igniter probe, to encourage a healthy spark.
Re the gas jet, some are a simple piece of shaped tin with a tiny hole in it. Others can be a tiny brass nut with a gauze inside. Don't go poking the latter. It's better cleaned out with an airline.
Yes, and if not at all sure, get someone in to do it for you. There are a number of mobile technicians about these days, without having to go to a dealership workshop.
Cheers,
Jock. :)
M
MH04RMV
84
186
Cheyenne 632 SE
Hi Dave Scadding JockandRita
Thanks for the advice - to clean things out, would they be accessible from outside via the vent, or would it be a case of pulling the fridge out (which I'm presuming has a flexi gas pipe connection to enable that to happen?)?
I tried lighting it/videoing it - it took 9 minutes and 30 seconds to light...unfortunately, even a 10 second video is too large to attach here, so I can't show the ignitor sounding just slightly different between failed and (albeit right at the end of the try) successful attempts.
To my totally unprofessional ears, it's almost like there's no gas until the finally successful try...but the hobs light up pretty much straight away once the gas is on, and I can't think of any reason the gas wouldn't be flowing to the fridge as quickly (the internal fridge on/off valve is at the "open" state, like the hob valve)...
Cheers,
Rich.
Jan 19, 2014
9,433
24,912
Derbyshire
Elddis Accordo 105
since 2014
Gas takes a while to get to the fridge but usually it's only after a long lay up when the gas feed probably is full of air.
Will it relight straight away?
Jul 20, 2018
440
1,233
Bridport Dorset
Swift Kontiki 655
Trailer tent for 10 years Motorhome since 2018
Cheers,
Rich.
Yep, if it’s a fridge freezer the lower vent.
Jun 10, 2010
8,612
20,459
Shrewsbury (sometimes)
N&B Clou Liner MAN
Cheers,
Rich.
is tha gas valve sticking? try tapping it.
Aug 18, 2014
23,960
135,752
Lorca,Murcia,Spain
Transit PVC
16 years since restarting
My basic 3 way fridge takes a count of 120 ( 2 minutes) to get the gas through. I push in & ignite once & hold in whilst counting to 120 then off & back on & it light s straightaway. It relights instantly every time. It only takes that long if it has been off or running on ehu for some days. The burner was cleaned out recently .
M
MH04RMV
84
186
Cheyenne 632 SE
Hello Richard n Ann
It can be a few weeks (or longer) between uses.
Do you mean, once it's successfully lit, does it relight? To be honest, I've never done an IT Crowd helpdesk and turned it off and back on again to find out, so I'll give it a go today (maybe the feed to fridge will still be part-filled with gas after only a couple of days?).
If it does relight straight away, what would that suggest - just a very slow gas feed (for some reason)?
I just had a thought...is there any way to "trick" the fridge/gas supply to fill the feed line without going through all the multiple clicks/starting procedure?
For example, if I left it "on"/dial selected to gas after the initial failure, would the gas still be flowing to the fridge, or is that only happening when the ignitor is firing (presumably as a safety thing, if e.g. it gets blown out by the wind)?
Cheers,
Rich.
Dec 24, 2014
9,318
48,099
Hurstpierpoint. Mid Sussex.
Compass Navigator
Hello Richard n Ann
I always had the same tedious multi-clicking lighting delay but on my 3-way fridge I now turn the knob to the 'Lighting' position and hold the knob in for say 10 secs to get the gas flowing and then switch on the igniter and it lights immediately.
