Does size matter? (2 Viewers)
Zigisla
2,580
3,106
Gosport, Hants
Sunlight A72
Forgive me if this is a stupid question, but I am newbie. :worried: I am looking into my first real project on my yet to be built, but arriving in 6 weeks unit.
Gas and the conversion to refillable. I have noticed on a lot of the threads some picture of the set up. Now 3 questions spring to mind straight away.
1: I don’t seen to have a bulkhead regulator / big thing at the back, why? Do have on folding Camper.
2: Some seem to have a small square refill point in the locker, but those who have the external ones have a much larger round filler. Is the gas pump nozzle different for eternal or internal filling? - is this why some have snags with not being allowed to fill abroad?
3: Some also seem to have the bigger fill point inside the locker.
Very confusing if I wanted to do a DIY job and save money for more shiny things.
:rolleyes:
Your help, advice and guidance always welcome
Yours Aye
Michael
23,836
72,549
I have my filler mounted outside the locker ( just cut a hole in the side skirt.. It is small, black and square.. I think it just depends on who supplies the kit as to the size of the filler. Mine came is an Alugas system bought from Autogas 2000.. It has been in two motorhomes so far :)
If you do not have a bulkhead regulator you must have the type that screws straight in to the bottle
It is no biggy to scrap that and fit a bulkhead one
I have a selection of adapters that screw in to the filler for use whilst abroad .. But even then I have been caught out.. I just asked in the kiosk and they brought out a large box of adapters to chose from and lend to me :)
23,836
72,549
Forgot.. It is a pretty easy DIY job providing you are happy using spanners.. Though if you are not used to working with gas I would suggest you get it checked by someone who knows their way around ..
Tips
Do not use TPFE tape on joints
When finished, make up a weak solution of washing up liquid and squirt it on all joints to check them
Peter A Forbes
270
184
Rushden, Northants, UK
Mercedes 614D
I think Jaws meant to type PTFE.
Having the filler point external is far better and possibly safer than in the gas locker, and you may find that you are prevented from filling at some service stations if you are seen to be opening the gas locker to do it.
Having a filler each side is also very handy on a large motorhome, and doesn't cost a huge amount to install.
Peter
2,349
10,209
I also fitted the filler on the skirt.. requires a 70mm hole saw.. that's the nervous part of the job.. :eek:
once cut and the filler fitted, the rest is just hoses, a spanner job..
While at it, I also changed the Truma regulator for a Clesse
Zigisla
Zigisla
2,580
3,106
Gosport, Hants
Sunlight A72
Cutting holes in a brand new unit :eek: would probably look into the locker filler, but from the picture yours Jim is sooo much bigger :rolleyes:, than the small square "locker" fillers or indeed like Jaw's external one as described above.
Do different manufacturers of the systems have different size nozzles then? Is that the Adaptors mentioned in Jaw’s post?
Spanner work I will be fine with, I hope after 35 years as a Naval Air Engineer.:D
And can these set ups be used without a bulkhead regulator then?
Yours Aye
Michael
2,349
10,209
The internals of the Gaslow filler are for the UK LPG gun.. it's only the plastic enclosure that makes it look bigger.. the filling part is the same as the surface mounted one.
yes, you need a bulkhead regulator ..
here you go.. took a picture
Zigisla
Zigisla
2,580
3,106
Gosport, Hants
Sunlight A72
Got it. Every supplier has the same connection. Body mounted just looks better. Adaptors, cos the European "guns" screw on instead of bayonet fittings.
Can I assume that these come in conversion kits or do you have to buy individually and of course the bulkhead connector would be separate as well?
and finally cos Im lazy, :sleep: approx price for a 2 bottle version like Jim's. :giggle: I will read up though on Gaslow v's gaskit v's alugas and whoever makes any more.(y)
Badknee
7,408
413,084
notloB
Vantage Neo
Living the dream.
In answer to your thread title I am reliably informed by SWMBO the correct answer is yes. :eek::cry::cry::cry:
Zigisla
Zigisla
2,580
3,106
Gosport, Hants
Sunlight A72
Am I reading this right. I cannot believe Gasit can be ÂŁ300 odd cheaper. Why does anyone use anyone else??
Unless it is a different system or the products are seriously inferior?
Al-Di
3,060
28,865
prestwich
Eura Mobil A Class
since 2013
gaslow & gasit are the same products, bottles made in Portugal, gaslow have a massive mark up(y)
32,673
66,648
If you go for the Gasit kit you can get a 't' piece which you attach to the bulk head regulator so you don't then need to by a manual, or auto, changeover either - that's what I did when I added a second bottle to my set up - when the gas runs out on one bottle I just turn it off and turn on the other, that way I know when it's been changed over so can then look to fill the other bottle up again.
When we got our new Globecar it didn't come with a bulkhead regulator (for some reason they like the bottle top ones!) so I had to fit one, not difficult at all.
We have had our Gaslow system since 2009, before Gasit came into existence, so have the larger round filler which I mounted in the gas locker but if I had to buy the kit again I'd go for the much smaller square one and mount it outside just under the bumper (we have a panel van conversion).
2,349
10,209
Incorrect they are not the same bottle.. and how do you know Gaslow have a massive mark up.. can you buy the SAME R67 bottles cheaper elsewhere ?
not necessarily inferior.. but there are some differences between the two products
when comparing two systems you must compare like for like.. your ÂŁ300 cheaper quote is for an in-locker fill point with no auto changeover valve.. plus
  1. Gaslow supply the R67 bottle.. a four hole bottle with an accurate level gauge which can also be used to transmit to a remote level gauge.
  2. The R67 has an inbuilt gas outlet filter
  3. Gasslow supply stainless steel braided hoses with a 15 year warranty
  4. The R67 has an excess flow shut-off valve.
  5. My price included all European adapters
  6. It included an auto changeover valve
these points may or may not justify the extra cost.. but when I fit, I fit the best I can afford..
2,349
10,209
are you not worried about road dirt getting into the filler point ?
32,673
66,648
No, it has a plastic cover on it, this was a picture of it on a friends van:
23,836
72,549
Peter
Cheers Peter.. fingers too far from brain !!!
andrewjw
206
242
Devon
La Strada Regent L
20 years plus
We bought our Gaslow bottles etc from...
Cheaper than from Gaslow directly together with great advice and service.
Odd but true!:)
Zigisla
Zigisla
2,580
3,106
Gosport, Hants
Sunlight A72
Many thanks to all who have contributed. It is a mine field out there for us newbies:). I certainly like the price of the Gas it system, but not at the expense of either conformity to some regs - foreign or otherwise, safety with regards to filters, burst v/v and the like or extras that you need to get in order to have a complete set up i.e. adaptors and change over v/v.
I am sure that this could go on for ever. My alarm thread seemed to::bigsmile:.
I will no doubt be back very soon with more "oh my God, not him again" questions.
Seems that I need a lot more reading time on gas first, before I talk about adding batteries and solar etc:D
6 weeks to go:clap:
Yours Aye
Michael
Sep 23, 2013
2,586
8,839
Lincs
Globecar Campscout
Ah - thanks Mel. That's answered a question for me.
When we got our Globecar, it had a bulkhead regulator, but in the bag of bits (spare sink plug, some hooks they hadn't fitted, a loo roll holder etc) there was a bottle top regulator with a short hose attached. I thought it an odd extra - the hose wasn't long enough for an exterior bottle.
Obviously the dealer had fitted the bulkhead regulator & put the old one they took off in the bag.
Peter A Forbes
270
184
Mercedes 614D
When buying the filler, make sure it has the 22mm internal thread to attach other adaptors to.
Otherwise you are stuffed if you want to go abroad to France etc. Holland uses the same fitting as the UK.
Peter
Al-Di
3,060
28,865
prestwich
Eura Mobil A Class
since 2013
@ScotJimland
taken from gas it website,
These items are our own, new manufactured and GAS IT branded stock and not simply repainted Gaslow ones.
Why pay Gaslow prices when our bottles are made in the same factory.
2,349
10,209
@ScotJimland
not sure what your point is..
I explained the difference between a Gasit system and a Gaslow R67 system.. post#15
Al-Di
3,060
28,865
prestwich
Eura Mobil A Class
since 2013
the point is, Gas it do exactly the same as Gaslow but cheaper, therefore i stand by my comment,
as many people on this site have found out,
2,349
10,209
whatever you say..
