Silver-Fox
Jesus, £1615 eachare trying to give Lenny a heart attack.
I glanced at it and thought it was £161
Glad I didn’t hit buy it now
More like what I was expecting, my 49° is pointing the gun straight in the heater outlet. Let's hope the controller allows me to tinker.Lenny, I have about 4 foot of ducting from the heater under the van to the outlet in the van, and I have just measured the temperature at the outlet in the van and it is 87.6c with the heater running at 5hz.
did you check if the controller is detachable?
Paul, I think the relevance was as in Steve's post earlier, re the heat outlet being adjacent to the thermostat within the controller.It is , but why does that matter ?
just looked at the picture and youve got the controller mounted near the outlets im prety sure that unit is a thermostat so if its adjacent to heat it will be cutting the output i assume it detaches to be mounted remotely as the other type of van heater would
And not one from the brochure. Most of them show a huge flame coming out of the outlet port, similar to RAF jet on after-burner.Pictures please, show us your heater.
Nice safe place to keep petrol containerHere’s a picture of mine in the garage and it works very well, and the wiring is a lot tidier now.
John.View attachment 575412
I am sure you will have had a look on Youtube, there are a few showing how to access the advanced settings.The controller barely gets warm so that's not the ptoblem.
Tried playing about with different compilations of buttons but I couldn't et into any settings. Got the display to show temperature setting, wound it up to max 35° it was no different.
If I don't have any luck it will be going back.
Agree with Paul on this one. If it’s got the soft tubing is under fuelled, less heat. From the pump to heater it’s got to be the hard plastic tubing.There was a reason why I asked about the fuel line, but no matter if it is going back.
Geoff
Mine has the soft tubing and is working fine.
John.
Had a look at it before firing up looked like the hard tubing.Agree with Paul on this one. If it’s got the soft tubing is under fuelled, less heat. From the pump to heater it’s got to be the hard plastic tubing.
Are they normally steel?Interesting that it's an aluminum cased version.
