Axle Weight Calculator
Jim
Ringleader
Sutton on Sea, UK
Carthago C-Tourer
Since 1986
Rear Axle Load Calculator
MotorhomeFun Logo
MotorhomeFun Rear Axle Calculator
Calculate how much weight you're adding behind the rear axle
Understanding the Fulcrum Effect
When you add weight behind the rear axle (like bikes on a rack, or rear storage boxes), it creates a lever effect with the rear axle as the fulcrum. This means:
  • The rear axle carries MORE weight than the actual item weighs - the further back, the greater the effect
  • The front axle loses weight - which can affect steering and braking
  • A 60kg load 2 meters behind the axle can add 90kg to the rear axle!
Use this calculator to ensure you stay within your vehicle's maximum rear axle weight limit.
Vehicle Setup
Rear Axle Load
1800 kg / 2400 kg
75%
✓ Within safe limits - 600 kg remaining
Additional Load on Rear Axle
+0 kg
Weight Removed from Front Axle
-0 kg
Add Items Behind Rear Axle
No items added yet. Add items to see how they affect your rear axle load.
