D+ (1 Viewer)
Lee Fryer
566
5,173
Eastleigh
Coach built CI Carioca 15
Since June 2012
I have a CI Carioca 15 2004 on a Ducato 2 does anyone know were I could find the D+ supply & fuse for the fridge & step, on the above I have found all the relays but for the life of me I cannot find this supply circled on attached drawing.
Jul 13, 2008
3,739
3,862
Low profile
Does the D+ control the step?
43,329
49,444
D+ will be any ign switch controlled supply.
I may be wrong but the D is a throwback to the days of the dynamo and the + denoted the 12v (or sometimes 6v) supply to the field or exciter windings in the dynamo which was activated by the ignition switch and made the dynamo windings live.
Today its just the charge warning light wiring.
43,329
49,444
I have seen that but were from, and were is the 1a Fuse, that's what i cant find.
Could be taken from anywhere.
Back of the alternator
Back of ignition switch
Ign switch controlled fuse in cab fuse box
Anything controlled by ignition switch.
Probably easier to start again with a new wire and fuse and pick your own source.
Lee Fryer
Lee Fryer
566
5,173
Eastleigh
Since June 2012
That's what I was thinking but thought I would ask on here in case some one had replaced the fuse. Thanks all for your suggestions.
Lee
DP+JAY
2,533
14,782
Dalbeattie
Laika 5009
since 2007, 25 years tuggin before that.
On our CI the fuses were all under the drivers seat & in the black box immediately behind it.
eddie
8,157
41,267
Taunton Somerset
RV
since 1989
D+ Is the wire that goes to 12 VDC when the engine is running and the alternator is producing electricity. Designed to operate the alternator warning light. You turn your ignition on and your "check lights" come on. Start the engine and they go out, hence the term checks lights.
+15 Is any circuit that is 12 VDC when the ignition is on
+30 Is 12 VDC from the battery positive
mike mcglynn
Jan 6, 2008
2,700
32,552
St. Helens MERSEYSIDE
Autosleeper Warwick XL
A long time now
hi on my 06 Ducato the relay For the fridge and the fuse was next to the cab battery
funflair
19,346
30,235
Guisborough
MORELO palace
since 2012
The D+ is only live when the engine is running as opposed to just an ignition switched live, it comes from the ignition switch and goes to the alternator windings via the ignition light, before the alternator starts to output this wire is grounded through the windings so the ignition light illuminates but once the alternator starts to spin it generates its own power in the windings so they float up to 12v +ve at which point the light goes out as +ve to +ve has no potential.
The other option is that the van control system is using a voltage sensing relay to determine when the alternator is running and supplying a pseudo D+, this could possibly be the case as the circuit diagram from @Lee Fryer shows the D+ coming straight from the Car battery and fused at 1amp so it's not going much work, if this is the case any 12 volt ignition switched live should suffice.
I am pretty sure our van uses the proper old fashioned D+ to the fridge as it shows -ve as opposed to open circuit when the ignition is off but I guess they are all different.
Martin
EDIT I should add that I am far from qualified in this subject so "buyer beware"
Lee Fryer
Lee Fryer
566
5,173
Eastleigh
Since June 2012
Thank's to every one, @TerryL you were right it was spliced into a alternator wire all now fixed
andy63
4,672
15,017
south shields
None
since 1990
can see all is sorted but ill just add a little info to the thread in case it helps someone..
I think most modern vans ( im on about panel vans , as I imagine most modern motorhomes already use a D+ , or engine run already in their power supply units and it should be easy enough to pick up ) there is often a wire that is simply ground switched by the ecu when the van is started , the battery is charging , and the engine is running at a certain speed..
that wire can be used to switch a relay coil , and the relay supplied with 12v to supply equipment that you only want to use when the engine is running , or to provide power to close a step etc..
on a mark 7 transit its taped up in the wiring loom just above the front
passenger wheel arch...
Andy
