cpap (1 Viewer)
saintliner
5
grimsby
van conversion
newbie
hi my name is brian we are newbies wondered if anyone can give advice on using cpap machine on 12 volts
thank you
17,630
43,338
it all depends on whether the cpap unit has the option of 12v supply. otherwise you will need a small inverter to convert 12v dc to 240v ac and some way to recharge the battery
jhorsf
9,130
8,045
DERBYSHIRE
ih oregon
I am sure someone on here has solved the problem and will be along to help when they read your post:thumb:
Jim
Ringleader
Jul 19, 2007
36,429
130,939
Sutton on Sea, UK
Adria Panel Van.
Since 1988
How much electric does it use. Does it have a plate/sticker with the power details?
chatter
3,689
937
cheshire
5th wheel
I think you would need a good bank of batteries to use one overnight, every night and you would possibly need an inverter attached to the batteries to run it. Then you would have to be able to recharge the batteries enough for the next night. Most people that need medical equipment overnight tend to use a small quiet honda type genny with inverter/sine wave technology the only problem with that is being able to make the genny secure enough when wilding.
There is a system called 'efoy' fuel cell but i dont know much about it, other than it is quiet
Geo
Trader - Funster
Jul 29, 2007
11,757
14,565
Mansfield,Notts
Autotrail Tracker FB
45 +years with breaks
No bill that's not geordie for a machine that don't work, that's spelt a "crap"
A CPAP machine deals with sleep/breathing problems
g8ysn
638
417
ng219ep
g8ysn
:Sad:wife usess a cpap, when we are away generally use campsite elecrtric when at meets etc make sure fully charged from genny [solar] through day, should last 6/8 hours so long as cpap back up battey is in good condition [should be inspected every 3 months] ask hospital teck guy, 6/8 hrs should be long enough to supply /maintain oxygen level:thumb:hope all goes well
17,630
43,338
for those interested, CPAP, or continuous positive airway pressure, is a treatment that uses mild air pressure to keep the airways open. Often used for people with sleep apnea or other breathing difficulties whilst sleeping
