DittoLots of solar and a couple of big batteries coupled to an inverter.
Sounds about right, my 300w inverter could theoretically draw 25-25 amps hence my 30amp fuse. I used to be an electronics design engineer specialising in....Inverters!! We always sought 90% efficiency, which was usually obtained around the 50-60% load. The quiescent current losses make bigger inverters 1000w etc. very poor efficiency at modest load levels. it's more efficient to have a 300-400w unit these ebike batteries will have an initial surge but settle in seconds to draw around 100w. Yours should easily suffice to charge a couple of ebike batteries simultaneously.My ebike has a Bosch motor and 625Wh battery, it’s supplied with a mains 2 Amp charger with a rated input of 100-240v 50\60 Hz 1.6 Amps. I have fitted a Victron 375W 240V inverter in my van. Ohms law suggests that the charger should draw a maximum of 160W, well within the rating of the inverter, at 100% efficiency one could expect a draw of 13.3 Amps. When I plugged the charger into the inverter with the battery connected charging started immediately but the inverter 12V current draw was only 7.5 Amps (90W) Given that the rated efficiency of the inverter is 89%, and that the charge time is specified as 8.8 hours from flat, (an unlikely scenario) which would consume 66 Ah I think that this is pretty good and well within the capacity of my batteries (190Ah) and solar(200w)/vehicle charging system.
me tooLots of solar and a couple of big batteries coupled to an inverter.
Your fuse at 30A will limit your inverter output to about 300w, I would use at least 100A fuse.My Inverter is 1000w, connected to the leisure batteries with in-line 30amp fuse.its tucked in close to the batteries near the fuse box and not really accessable so I installed a further accessable13amp plug socket which is plugged into the inverter only. Use this for charging the bike batteries whilst running and on sunny days. Alternately. Plus can also plug in other items for charging and using, microwave for a few miins as an example if off grid and we have good solar.
The quoted battery capacity is very small for an ebike, 8Ah/288W/h I would be very surprised if you get anywhere near the quoted 60km range unless you’re cycling somewhere very flat and don’t use much assistance, but it is supposed to be a mountain bike ?. Also, Gadget John fitted a supplied accessory throttle, this is illegal In the EU for an EPAC so I wonder if this bike is type approved? It may be apocryphal, but I read somewhere that the Spanish police were checking ebikes for the correct markings!any reviews good or bad for the AS Mk 3 electric bike I’m thinking about getting one
Bought ours second hand, had no issues. Fold up for storage and fit on the bike rack. Batteries and saddles stored in the van.any reviews good or bad for the AS Mk 3 electric bike I’m thinking about getting one
DittoWe use an inverter and only charge while we are driving.
Is that the same inverter shown below?I bought a Bestek 300w Sinewave inverter, and wired it directly to the leisure batteries (via a 30A fuse). It enables me to charge up my 2 ebikes (Rally Arrays) whilst driving. The inverter does have a cigar lighter plug option, which is best stored in a dustbin. I don't have solar so only use it when engine is running.
Voltage is not the issue as the bikes charger will see to that. What is important is the chargers input wattage or amperage.The batteries are 36v so what would be a good size inverter to have and how do you install it
That's like it, as I said cut the cigar lighter plug off throw in the bin, then put on a couple of connectors from Halfrauds.Is that the same inverter shown below?
Amazon product ASIN B076P9PGX3
If so we bought one works very well for the toothbrush and laptop but not for the ebike batteries as the charger draws about 250w, too much for the 12v plug had wondered about changing the power lead but not sure how.
It depends on the charger, I decided with the price of Bosch spares it wasn't worth the risk.Do e-bikes batteries need a pure sine wave inverter for charging when driving or would my 1500 watt modified work ?
Battery is 36v 10.4Ah 374.4 Wh Charge max 1.8A
