AndyPK
- Oct 7, 2015
- 5,015
- 13,923
- None……..!
- Motorhoming since 2015......
Were you in ‘Ello Ello’........?My spill chucker is rooobishh
It can trigger far worse so my dealer informed me. Even scramble the ECU's mmarbles.Apparently, if you start the engine before tthe lights on the dash have cycled and gone out it can trigger a warning light. Best to let all the start up sequences go through their stuff.
Oh no another ex spertEngine Swarf ?...
maybe years ago. Modern Engine build tolerances do not permit engine Swarf now.
Fully synthetic oil does not degrade like mineral oil used too.
I would not change the oil at this point in time. Minimum of 6000 miles or 36mnths
Clemmo ( Automotive Engineer)
Oil level ok, and the ‘oil can’ light does not stay on after engine starts, so it’s just the ‘change engine oil’ that cycles twice, and then goes off. I’ll try the accelerator/brake pedal fix today and see if that helps........If you have checked the oil level as per message and it is ok the it is almost certainly an electrical fault. Possibly the oil level sensor! I had the yellow generic light appear on my Ducati. Oil level sensor. Software update. Still there. The sensor is about £40.00 but it in not accessible without dropping the engine subframe!!!! The Fiat lot did not want to do this. A call to Customer services in Milan an they agreed to do the work without charge although by this time the 2 year warranty had expired. IVECO at Hildenborough undertook thé work they have high workshops with big lifts which you need for this job
Sounds like the sensor may be at fault. Make sure they put it on their diagnostic system to check this out, don’t be fobbed off or it could cost over a grand. To change the oil at this mileage will only benefit the coffers of the Oil Companies and your Peugeot Dealer.
When you say time period do you mean it will go off on its own eventually.Ive got the same on my Ducato change oil warning and flashing red oil can . It comes on a time period two year cycle.
The reason I ask is I have just change oil on my Fiat Panda and the change oil lights has come on.. Probably not same setup but who knows????
swarfe's brotherWhat’s an ‘engine dwarf’.........?
You'll be an egg spurt nowCurrent vans have an oil degradation counter in software. There is no fixed service interval for oil changes, only maximum intervals based on time, mileage or the "Change engine oil" message being displayed. It is certainly explained in the handbook supplied with new Ducatos.
There have been instances of a fault y sensor causing the oil change message to appear too early, but as the 2 year change interval is an absolute maximum and no longer a fixed interval, and as the engine manufacture also recommends annual oil changes for vehicles that travel less than 7,500 miles per year, plus an oil change prior to running any vehicle that has not been driven for more than 3 months, it's not worth ignoring an oil change in my opinion.
