- Nov 22, 2018
- 1,802
- 15,193
- Rimor Europeo 87
- Five years plus three tugging
Two weeks ago, three days before we were due to catch the Channel Tunnel, a cast iron manhole cover on our drive shattered and we had a wheel wedged in.
Couldn't drive out, or use the jack, so it cost £180 to get winched out as breakdown insurance won't cover it.
Subsequently found out that most cast iron sewer covers are rated at 1.5 old tons. And ours were originals from 1959.
I've got two drain covers down the side of the house, so I decided to get two pieces of 6 mm steel plate. Extensive search and I wasn't getting change out of £100 incl delivery.
Went down the local scrap metal dealer and he found a bit of old plate which he cut to the required size (go double the size of the drain cover) and took only £25 off me. I'll be painting them with a rust proofer this weekend.
I would humbly suggest that if you have a 3.5 tonne or heavier and you are still driving over your cast iron manhole covers, get some 6mm steel plate (or 8mm if over 3.5 tonne). Ugly, but cheaper than forking out for a winch, or worse, replacing the cover and concrete surround with reinforced 5 tonne covers, which will cost more than a few grand.
