Auto Dump Valve (2 Viewers)
Jun 30, 2010
7,924
27,230
1992 VW Auto sleeper Mono
Since 2005 this time
Seem to have a bit of a problemo, My Frost Protection Dump Valve isn't working, it won't close:Sad:
We last used our M/H in Jan, when we came home we (actually thats ME!, Mrs R thinks she's on holiday as soon as we leave the drive, and when home "technical stuff is your Department"), But I digress!:Doh:
I emptied the System, wiped out the Tank, left all taps open and pushed the dump Valve down, to open it.
Today, because we are going to a Rally over the Weekend , I decided to test the system, only to find the Valve no workee:Angry:
Question; Did I do something wrong?:Doh:
If the valve is U/S where do I get a replacement, and if I have To, can I bypass the blinking thing temporarily, without causing a problem until the part arrives.
Tried Geoff Cox, still waiting to hear back from them.
Any advise gratefully received as always: :notworthy::notworthy:
BwB
917
1,170
Suffolk UK
Resting b'twix vans
Since 1990
What was the air temp when you tried this? I only ask as I did the same thing today and had a bit of a panic but then wondered about the air temp where the valve is. So waited until this afternoon once the sun had come 'round and bingo, it stayed up.
We had quite a heavy frost this morning so I guess the 'van took a while to warm up.
Just and idea.
PS, a peg is the temporary answer to the fix. Lift up the plunger and clip it with the peg :)
Munchie
8,921
12,581
Camping Les Vigeres
Font Vendôme
Will watch this with interest as ours "dribbles" occasionally. Is this normal or do I need to think about a replacement? Thanks. :Smile:
Popeye
Sep 5, 2011
7,926
86,461
edge of New Forest
Frankia Platin Plus
On and off since 1983
Will watch this with interest as [HI]ours "dribbles" occasionally[/HI]. Is this normal or do I need to think about a replacement? Thanks. :Smile:
I think that might be an age thing Ken, I'm not looking forward to it at all.......:roflmto:
Bugger, Pappajohn beat me too it.......::Doh:
GJH
29,450
38,827
None, now sold
2006 to 2022
Just and idea.
Could well be the cause. Our previous van didn't have an auto valve so we're having to get used to it on the Burstner. We have had to run the heating for a short while a couple of times to raise the temperature around the valve sufficiently for it to stay closed.
rangi
Jun 30, 2010
7,924
27,230
Just and idea.
Yeh thanks BwB, it was this arvo, and warm, and yes, did have a peg in place, but pump kept working after the system was bled, and water kept exhausting from the system, still thinking of By passing the Valve, until I can get hold of a replacement.
But it seems slagging yer mate off is the go:Angry:
1948
444
49
surrey
hymer A class
since 2010
When I 1st used the dump valve, I thought that it was not closing as it kept dropping when I tried to close it by lifting the valve. Eventually realised that I was not pulling the valve up firm enough so gave it a hard pull and it locked into place Could you be experiencing the same problem??? Just a thought, give it a hard pull and see what happens.
JockandRita
11,462
150,189
Lincs/Cambs border
N+B Flair 8000i
Since May 05 (Ex Tuggers).
Hi Rangitira,
If you don't have power to the valve, it will not stay closed at ambient temperatures below 6 degrees C. Turn on the heating but turn the thermostat right down, to prevent the heating coming on, that way, you are only powering the dump valve, and not using any gas
HTH,
Jock.
pendy
153
97
Birmingham
Hi Top
3 yrs
Just for information purposes, the new style valve on the Caioca has a tap type lever you need to realign, and then there is a reset button to push!! How do I know, I did mine over the last weekend!! HTH:cry:
Jan 3, 2008
3,341
5,359
Pakefield, Lowestoft, Suffolk, UK
Looking
Dribbles
We have the Truma C6002 gas and electric boiler with the electronic dump valve. Ours had the "Dribbles" last year and cleaning out the system with vinegar in the hope of removing any lime deposits did not work. I got a replacement from the retail arm of Tuma, which is called Miriad Products. Around £50.00 or so. This cured the problem and was easy to fit DIY.
Interestingly the electronic valve has now been superceeded by the new non electrical type so I wonder if these things had been giving problems
rangi
Jun 30, 2010
7,924
27,230
Thanks Fellas some good tips there from you all. Had decided to change the valve from Auto to Manual. But tried the Hair dryer (well paint stripper gun) and it worked
All power to you all:notworthy::notworthy::thumb:
