Hi all,
Peugeot Boxer 2016 pvc…
Out of the blue these warning lights are showing
, manual says ‘ peugeot dealer fix’
Just wondering if theres any kind of reset procedure or investigation I could try before going down the costly route…
When ours came on, we assumed one of the ABS sensors had failed. It turned out a mouse had chewed through the wires!
If you can get a look underneath and see whether any of the wiring near the wheels is damaged/loose, it might be as easy as cleaning and pushing the connector back together. If not that, then it could be a failed sensor or rodent damage and a garage with the right equipment would need to check.
Hi Rob
Went underneath and eventually found the attached damage, took van to superb local garage ( suttonz eastbourne) who found a bit more damage to air suspension plastic lines. Bugger. Not rodents, looks like a branch or something … dont remember hitting anything but at least I know its not an electrical ‘fault ‘ and its booked in for repair , thanks for prompt reply
