Anyone know if theres a reset for this warning light? (1 Viewer)
Jan 1, 2017
1,161
2,618
eastbourne
van conversion, Peug
4 years
Hi all,
Peugeot Boxer 2016 pvc
Out of the blue these warning lights are showing
, manual says ‘ peugeot dealer fix’ 😬
Just wondering if theres any kind of reset procedure or investigation I could try before going down the costly route…
Jul 29, 2020
110
260
New to motorhomes, had a camper van before this.
When ours came on, we assumed one of the ABS sensors had failed. It turned out a mouse had chewed through the wires!
If you can get a look underneath and see whether any of the wiring near the wheels is damaged/loose, it might be as easy as cleaning and pushing the connector back together. If not that, then it could be a failed sensor or rodent damage and a garage with the right equipment would need to check.
Cheers,
Rob
uzsnowdrop
Jan 1, 2017
1,161
2,618
eastbourne
4 years
Hi Rob
Went underneath and eventually found the attached damage, took van to superb local garage ( suttonz eastbourne) who found a bit more damage to air suspension plastic lines. Bugger. Not rodents, looks like a branch or something … dont remember hitting anything but at least I know its not an electrical ‘fault ‘ and its booked in for repair , thanks for prompt reply
Jul 29, 2020
110
260
No problem - at least it was pretty obvious when you got under there!
Fingers crossed the repair bill won't be too eye-watering.
Cheers,
Rob
uzsnowdrop
Jan 1, 2017
1,161
2,618
eastbourne
4 years
Thanks again
I know they won't rip me off , they are a good bunch but I can guess it won't be cheap!
Vanlife eh!
Cheers
