Any ideas what this could be (4 Viewers)
Mar 16, 2010
3,057
30,761
Carmarthenshire
In between
Since 1988
this switch is at the side of the steering column.....when the ignition is turned on and it is switched on the light illuminates.
Dec 4, 2014
1,372
4,148
Cheshire
Been around the block a few timesšŸ˜‰
I have the reversing camera on an identical one.
Debs
6,302
181,666
West Notts
A class Adria Vision
Anne I posted a similar thread with pics on our first trip out last Sept but can't find it.........turned out to be for spotlights:blusher:
Badknee
7,408
412,835
notloB
Vantage Neo
Living the dream.
Rear fogs on our import Eunos Roadster
Sep 3, 2012
7,554
26,067
Cheshire
C Class Elddis 175
8+ years
the hole looks as though its missing an LED warming light also -maybe a check under/behind the console will determine if it has been pushed in.(y)
Peetee
30
36
Hampshire
Carthago
Reversing camera when in forward motion
Sep 25, 2009
794
1,386
south yorkshire
since 2004. Tugger 10 years on and off
Just had same switch fitted to mine.I had a new sound system fitted.Mine is used to take power from leisure battery.
D
deleted-member02
To activate the bike loop on a Strikeback alarm ?
davanne
Mar 16, 2010
3,057
30,761
Carmarthenshire
In between
Since 1988
Anne. It's a button which you shouldn't touch without proper training. :)
Something bound to go wrong if I press it ..how did you guess Andrea
thanks Debs internal or external????
davanne
Mar 16, 2010
3,057
30,761
Carmarthenshire
In between
Since 1988
Do you have a strikeback alarm !
No strikeback alarm......and the led only lights up when ignition on
nothing behind the hole but the switch itself has an led
davanne
Mar 16, 2010
3,057
30,761
Carmarthenshire
In between
Since 1988
With my strikeback alarm there is one as your photo which arms the internal sirens and one without the light which is for the rear bike loop.
Had the same on a previous van with strikeback alarm but not one fitted on this van
bhs
214
137
Louth
b class
since 2006
Bought a bunch of those switches on ebay, have two in a similar position, one works the radiator cooling fans over ride and one turns on reverse camera when driving.
Allanm
5,431
9,192
Cotes d'armor, France
Burstner Harmony TI 736 G
Since 1987
override switch to power internal lights when the engine is running? I can only think of two ways to figure out what it does. Trace the wires or start the engine with the red light on and see what works and what doesn't. Then do the same with the led off.
Ok, that's 3
Or (4) start the engine while someone else looks round the van while you turn the switch on and off.
Of course, it could be something to do with the leisure battery charging, or solar panel, if you have one.
Not really much help was I?
Debs
6,302
181,666
West Notts
Allans suggestion of getting the engine running & someone have a walk around is a good idea(y)
Ours were external spots, only lights when the ignition is on.....but if you can buy them from ebay I suppose it coukd be linked to anything:eek:
Good luck!:D
davanne
Mar 16, 2010
3,057
30,761
Carmarthenshire
In between
Since 1988
Ok, that's 3
Yes we do have a solar panel... Will try your suggestions tomorrow thank you
gozomike
Funster Life Member
1,001
863
Warwickshire - sometimes - but not often
Wildax Constellation
Since August 2008
I take it this is a pre-loved van (I think that is the current politically correct term:rolleyes:), in which case has a previous owner fitted an accessory and then removed it when selling the van. In which case the switch will do nothing.
