Alternator amperage (1 Viewer)
Bart
3,188
1,398
Northern Ireland
Boxer L4H2 van build
Since 2016
How do i find out the amperage of the alternator fitted to my 2007 Fiat Ducato Bessacarr E560.
I am looking to find this info out as ive been reading about a Sterling B2B charger for when i get the money to install solar i would prob fit a B2B charger at the same time.
Abacist
3,780
11,019
Devon
N & B Arto 88F Tag
since 2013
I don't remember having to be worried about the amperage of my alternator when I fitted my B2B charger. I just fitted it but it hasn't been used in anger yet. Mine's an X250 3 litre and if the alternator needs to be replaced in due course I'll get the most powerful that will fit.
43,365
49,701
There may be a few different outputs depending on original chassis design use.
A minibus type van will spend hours on motorways etc so doesn't need masses of electrical power but a short haul delivery van May need starting many times each hour so needs to get charge back in the battery quickly.
Best place to find out would be Google with ALL your vans base details.
53,620
150,700
The part number should be stamped on the alternator, may take a bit of finding but easy to find the spec once you have it. Have you rung or emailed Swift or asked on their forum?
Bart
Bart
3,188
1,398
Northern Ireland
Since 2016
From what i seen from a video Mr Sterling done he said it was pointless buying too big of an B2B charger as your alternator would not be proving enough juice to use of the B2B's potential and you would be wasting money , mind you at about £280 - 300 for a 60 amp version i don't think ill be getting anything bigger than that :)
but having said that if my alternator was was something like 70 amp , then some of the 60 amp B2B would still be wasted as the alternator has to take some of that 70 amps to run the vehicle / wipers , radio , heater etc.
Bart
Bart
3,188
1,398
Northern Ireland
Since 2016
nope only started to look into B2B charger tonight when i started to do some research into what battery charger to buy :D
I'll see if i can get anything from the alternator tomorrow when i look to see if anything is stamped on it.
Abacist
3,780
11,019
Devon
N & B Arto 88F Tag
since 2013
You might struggle to get near the alternator to see anything as its low down at the back of the engine on the offside with sub frames, steering rack, exhaust etc in the way!
53,620
150,700
I think the smallest alternator on an X250 is 90 amp most converters fit an uprated one I think the one on Hymers is 160 amp.
43,365
49,701
I would expect its nearer to 150amps.
With today's technology and electrical demands the days of a 65amp Lucas alternator are long dead.
My car runs a 180amp alternator.
Bart
Bart
3,188
1,398
Northern Ireland
Since 2016
@Abacist i sort of thought this , but my plan was to lie below the vehicle and take 10,000 pictures of the alternator and hopefully one of them give me some info :D
@Lenny HB & @pappajohn thanks for the info , i have just went to a parts suppliers website and entered my vehicle reg , then looked for replacement alternators and it listed about 7 of them all were in the range of 110 amp >> 180 amp , except one that had no amperage beside it and it was like half the price of the rest.
So tip i would say min of 110 amps hopefully :)
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
Only way to know what is fitted is to poke your phone at it and click
Here a 2008 3 litre
Feb 9, 2008
4,094
5,915
SW Scotland
LP Coachbuilt
Why fit a b2b charger if you are going to fit solar. The panel will charge both batteries and should the chassis battery drop just c/o on the panel to run off the cab battery. Works for me.
Bart
Bart
3,188
1,398
Northern Ireland
Since 2016
The solar panels would go in 1st as well at the battery upgrade , the B2b charger would be added then if needed , but at the very least the "factory fitted" charger would need changed.
I just like to do a lot of research and get opinions :D sure no harm in that.. (y)
R
Robert Clark
A B2B charger is association with solar is a complete solution - especially if you're considering an inverter.
We had a Sterling 60a b2b charger in our Bessie.
The other thing to consider is if you need extra leisure battery capacity.
Feb 9, 2008
4,094
5,915
SW Scotland
LP Coachbuilt
We are pretty much self sufficient on only one battery and a 100w panel, though not in the winter when we are only good for two or three days. I did look at an extra battery but the location and extra weight were problematic.
TerryL
6,189
8,194
North East
Low Profile
Our Bolero is same layout. Sterling B2B was first thing we added, then an extra battery (fitted in a new battery box under the offside bench). That proved good for around 6 days so eventually we fitted a 100w solar and find we're now totally self-sufficient. Also fitted a battery mate to keep the vehicle battery topped up when static. With this setup you shouldn't need to worry about the vehicles own battery charger, 10amps ought to be perfectly adequate.
As regards the alternator, when ours failed (nothing to do with B2B) the garage wouldn't order a replacement until they'd identified the unit actually fitted as there 3 different alternatives.
Bart
Bart
3,188
1,398
Northern Ireland
Since 2016
Weight is something else i have to look at. :(
Bart
Bart
3,188
1,398
Northern Ireland
Since 2016
Good to hear about you experience with your sterling B2B , what amperage / model do you have ?
Also whats a battery mate ? is that like a warning device for your battery level ?
Do you have an invertor ? if so what size and is it just for the likes of hairdryer / microwave ?
So many Q's >><< :)
Abacist
3,780
11,019
Devon
N & B Arto 88F Tag
since 2013
To my mind the B2B comes first as we move almost daily so the engine does its work. In addition the solar is not so good in the UK especially in winter but is good abroad in the summer. It depends on your pattern of use. The B2B is an easy quick fix with extra batteries and an inverter but the solar is a bit more work to get organised and plumbed into the van and the electrical system. Just my opinion of course.,
Techno
Jul 28, 2010
15,475
20,756
May 2010
My present set up (I was going to say current ) Best price is about £299 delivered
Bart
Bart
3,188
1,398
Northern Ireland
Since 2016
Not all year it won't
Nothing wrong with a b2b and essential in my view and the 60 amp IP68 unit is so small and quiet.
View attachment 115359 View attachment 115360
I would say our travels should be 1-2 days max stay at one place , hey that why we have wheels :D
So would you recon i should put Solar or the Sterling B2B charger at the top of the list ?
Andy when you say your set up , i take it you were meaning just your inverter ?
Is this your inverter ?
http://www.sp-shop.co.uk/Sterling-P...o-Battery-12V-12V-60a-Charger-PN-BBW1260.html
